Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Lights won't go on
We have two outside driveway lights that are set by Intermatic timer. The lights no longer go on after years of being fine. I replaced both bulbs. I manually turned the timer to the on position. I cannot seem to get the lights to go on. Any ideas?
  • dmilstone Jun 04, 2010
    Thanks - but the timer itself is working as evidenced by the noise it makes (the dial moves according the time) but even if I move the on/off switch on the timer manually to "on," it still does not activate the lights.
    I've tried all of your other ideas and none seem to rectify the issue thus far.
    Thanks
  • 565 Answers
Sounds like the timer may not be getting power.
Turn the circuit breaker that supplies the circuit OFF then ON, as sometimes it's hard to tell if a breaker has tripped by looking at it.
It's possible that the circuit is controlled by a switch that someone may have inadvertently turned OFF.
Also, it's very likely that the circuit is fed from a GFCI receptacle (the kind with the test and reset buttons that are usually found in kitchens and bathrooms) that may have tripped. Those receptacles can sometimes be found in very obscure places. Check outside receptacles too.
If anyone has been digging in the yard or flower beds it's possible that the cable may have been damaged.
Posted on Jun 02, 2010
  • Bob
    Bob Jun 04, 2010
    The first step is to determine if you have 120 volts at the timer. You can use a volt tester or a light socket to test the circuit. If you have an Intermatic T101 you should get 120 volts between the "A" terminal and the #1 terminal.
    If you have 120 volts at the timer, turn the manual lever to ON and test for 120 volts at the lights. It's also possible that there is a bad connection at the light box. If you don't have 120 volts at the lights, then either the cable to the lights is damaged or the timer has a mechanical failure and needs replaced.
  • Bob
    Bob Jun 05, 2010
    If you have an Intermatic T101 you should get 120 volts from the "A" terminal to the #1 terminal. With 120 volts available, when the manual lever is in the ON position, you should get 120 volts from the "A" terminal to the #2 terminal. If not the timer needs replaced.
    Alternatively, turn the circuit breaker supplying the timer OFF, then temporarily remove the wire that is connected to the #1 terminal and put it under the #2 terminal (which also has the wire going to the lights.) Turn the circuit breaker back ON and, if the circuit to the lights is OK, the lights will come ON.
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
I have an Intermatic ST01C timer. Works great. I just noticed that I cannot set the DUSK time past 9:11pm. Any minute before that is fine such as 9:10pm but I wanted to set it to about 9:15pm. It has...
Call Intermatic.
You can set dawn-dusk parameters a bit longer or shorter than pre-programmed dawn-dusk times.
There is a limit to how many minutes you can add or subtract to pre-programmed times, and I'm not sure how many minutes exactly.
All astronomic timers have limited number of additional minutes, and folks write to fixya occasionally about wanting to extend the limit. But there is no work-around unless you choose to set fixed on-off times instead of using astronomic feature.
If timer begins to malfunction, you reset timer and change CR2 battery, and then reprogram the timer.
Instruction manual has troubleshoot checklist.
Timer comes with 1 year limited warranty.
Open following links for ez instructions, wiring diagrams, and battery illustration:
http://waterheatertimer.org/ST01C-program.html
Jul 29, 2011 | Intermatic Inc. ST01C Digital In-Wall...
My HB1116R TIMER STOPS RUNNING ON OFF WORKS FINE thank you in advance if i tap on housing i can hear timer starting for a few seconds
If the timer dial will not push the tripper past the on-off lever, or if dial is no longer rotating, or is rotating slow, then clock motor has gone bad.
There are no replacement clock modules for HB series timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
You can set timer to override and plug HB into another plug-in timer
Intermatic site no longer shows HB series outdoor timers except for HB8800.
http://www.intermatic.com/products/ec%204%20layer/plug%20in%20timers/plug%20in%20timers/plug%20in%20timers.aspx
Amazon still sells HB1116R
Jul 07, 2011 | RTO Intermatic HB1116R Power Stake With...
After 7 years working properly, the event button has stopped working. There is no way to start the load in manual, or to change the program... What can I do?
You posted under EH40 Intermatic programmable timer.
EH40 Manual:
http://waterheatertimer.org/pdf/eh40-manual.pdf
1) EH40 uses size A battery. Replace battery.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#Battery
2) Reset the timer: Press and hold reset button for several seconds
3) Contact Intermatic because they are aware of specific problems with specific timers
http://www.intermatic.com/customer%20service.aspx
4) Other folk have reported EH40 and EH10 last about 3 years.
EH40 has 1 year limited warranty.
I test timers: 7 years is reasonable run for inexpensive electronic time switch.
5) For longer lasting timer, consider Next Generation: battery is replaced every 8 years
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Intermatic EH40 - Electronic Water Heater...
Outdoor lights timer: Intermatic HB851 photo timer with dial. How do I set it for dusk ON then off in 8 hrs.
Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
Timer turns on automatically at dusk.
Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
Feedback from lights will cause timer to reset the 8 hour countdown.
A car pulling in the driveway can cause feedback.
If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
Dec 18, 2010 | Woods Outdoor Lighting Timer
The wall timer to my outside lights says "noop"
noop means no operation.
This usually shows on older timer.
You posted under Intermatic ST01C.
Other have written to fixya with same symptoms.
CR2 battery might be bad. Replace battery.
Replace battery quickly and current time remains in memory.
Battery out of timer longer than 30 seconds, then current time and day disappear.
Programming remains inside timer forever with or without battery until timer is reset.
Others report they changed battery and timer never came back to life afterward.
http://waterheatertimer.org/ST01C-program.html#battery
Manual troubleshoot section also suggests resetting timer, and then re-programming.
Manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
To reset timer, hold down ON-OFF button and push small round reset button with paper clip.
Push reset for 3 seconds and release.
Keep holding down ON-OFF until INIT shows on display.
Release ON-OFF and wait for display to show.
If display never shows, then battery is dead or timer is bad.
ST01C comes with 1 year limited warranty.
Advantage of Intermatic battery operated timer is simple wiring, plus astronomic function (dawn-dusk).
All in-wall timers have advantages and disadvantages.
Nextag shows new ST01C sellers
http://www.nextag.com/intermatic-st01c/products-html?nxtg=90ff0a280507-C4F7FB4C58223A3F
Page also shows Intermatic EI600 astronomic timer that comes with 5 year limited warranty
Nov 29, 2010 | Intermatic Inc. ST01C Digital In-Wall...
The instructions on how to operate this timer are sooooooooooooo microscopic, I cant ev en read it with the magnifying glass I have here! Please tell me where I can go on line to get these instructions so...
You can go to their web site. They are still small but you can zoom in on them. Go to their web site here: http://www.intermatic.com The link to your timer is :
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/st01c%20-%20english.ashx
Oct 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
533 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
