Question about Sylvania CL772B 17" Flat Panel LCD Monitor
Cl772b sylvania (model 780) go to white screen after 10 sec power on. No visual signal of damage.
  • 11,361 Answers
You get white screen glow when the T-CON board on the LCD panel does not receive the +5dvc feeding it or it has blown fuse on the T-CON board, see picture of the T-CON board and the fuse here:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Look at the logic board to see if the ribbon cable may have come off the LCD panel or the logic board, also look to see if you can see any bad caps (leaking/bulging top).
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 31, 2010
Sylvania 780 with windows 7 powers on but won't display
My sylvania cl772B turns on and shuts right off. what can I do?
Nov 10, 2012 | Sylvania CL772B 17" Flat Panel LCD Monitor
Lost power cord to monitor
-usually the power cord for the monitor and the desktop computer is the same
-try connecting the power cord of your computer to your monitor and if it fits you can go to your local computer shop and buy a power cord for your desktop computer
Nov 22, 2010 | Sylvania CL772B 17" Flat Panel LCD Monitor
I was given a 17" flat screen monitor and the cable to connect it to the computer plus the power cord are missing, can I replace them?
yes. you can replace them with replacement cable for monitors. Just go to your nearest computer store and ask for replacement cables provided with the Brand Name of the monitor.
Aug 31, 2010 | Sylvania CL772B 17" Flat Panel LCD Monitor
Blue numbers on screen in the upper left. reset only helps for 5 sec.
The text reading on the screen is 772S L7025 AU M1 70ES05 and are always present over applications? If restoring factory defaults, changing resolution does not help then the monitor will need to be repaired, sorry.
Jun 20, 2010 | Sylvania CL772B 17" Flat Panel LCD Monitor
Sylvania 780 wont stay on for more than 10 seconds than I have to press the on button again and it goes off after 10 secons again.
If you are going to DIY repair, please read below and look at the pictures in my albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 03, 2010 | Sylvania CL772B 17" Flat Panel LCD Monitor
I have a sylvania monitor model CL772B. The light is green and flashing after a power outage. The manual doesmnot describe this condition. There is no screen image. How can I correct the problem? If needed...
This seems to be issue with the Computer not the monitor. Check the monitor with different computer or you can check the monitor also. For this take out the monitor cable from the tower and turn on the monitor alone, if you get any message on the monitor screen it means that monitor is fine. Try this and let me know.
Apr 12, 2010 | Dell Computers & Internet
GATEWAY FPD1500 MONITOR POWER ON BUTTON TURNS GREEN FOR A SECOND, THEN TURNS ORange! and nothing ahows on screen,, i tried plugging it to my tower, and no response from monitor. plese help!!1
check when you plug it in all the copper wires are placed correctly and if that dosnt work while it is plugged wiggle it a bit and if that doesnt work wiggle it more
Jun 13, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Flashing green power button
the monitor green light comes on but the monitor itself does not come on. Sylvania LCD CL722b-Model 780
May 16, 2008 | Sylvania CL772B 17" Flat Panel LCD Monitor
Sylvania CL772B 17" Flat Panel LCD Monitor Logo
219 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
