Question about Dryers
220v dryer need to know where the wires go on a 220v dryer
  • 5,911 Answers
If this is for the standard USA electrical distribution, the power cord connections to the terminal in the back of the dryer are as follows:
3-PRONG:
RED (HOT) - to the RED wire at the terminal
BLACK (HOT) - to the BLACK wire at the terminal
WHITE (NEUTRAL) - to the WHITE wire at the terminal (this is the center lug on the terminal).
NOTE: Some dryer cords may not be color coded. Just ensure the the center wire goes to the center terminal (neutral) of the terminal board. The other two wires are HOT and it does not matter how they connect as long as they go to the two outer lugs on either side of the Neutral.
4-PRONG:
GREEN (GROUND) - to the equipment chassis. (this is usually a separate lug that grounds this wire to the equipment cabinet or frame.)
I hope this helps you. Please post back if you have any further questions.
Posted on Apr 08, 2008
I just picked up a clean touch dryer and the cord is 220 the plugs in my house r 120 how and where do i connect the 120 cord
You cannot un a 220v machine on 120v
DO NOT change the wire on the machine
Have an electrician run a 220v line to where it's needed
Feb 08, 2011 | Whirlpool LGQ9858P Gas Dryer
How do i wire the back panel on my dryer
if your asking how to put on a 220v line on? if you are, all you need to know that the middle wire needs to be in the middle. the outter wires can be put on either side.
Jan 10, 2011 | Dryers
I have both washer n dryer that are 220v 4 prong each but theres only one 220v 4 prong wall outlet. do they make splitters for this ?
I would say no. I have never heard of a 220V washing machine, as a washing machine has no need for 220V. In any case though you would need to get the appropriate wire, cord and outlet and install a separate circuit for the washing machine.
Nov 02, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer getting hot but not drying
YOUR DRYER will start and run with only 110v. applied to it...........................How ever you won't get heat without 220v..........after you run dryer a few minutes you should feel HEAT inside.......my guess is you have no heat but the dryer runs,,,,,,,? If this is so, you probally are not getting 220 volts. you either have a blown FUSE or a bad circiut BRAKER in your main panel... remove cover (the small one) on back of dryer where the plug cord goes in....get someone with a voltmeter to check for 220v. going in to your dryer,,,,,,,,,,BLACK(wire) toWHITE(wire)=110v...........RED(wire) toWHITE(wire)=110v.........BLACK(wire) to RED(wire)=220v.............Let me know how you make out....P.S. don't go on ROOF..!!!!
May 11, 2009 | Whirlpool LER5636P Electric Dryer
I need to wire a 2HP 110V ge motor to 220V
I think the only place you will get this info is from GE -- and good luck with that.
Apr 29, 2009 | Dryers
KENMORE DRYER MODEL #96263800 WON'T HEAT
Need to know brand name and model#..........but it sounds like your only getting 110volts to the dryer instead of 220volts........The moter and controls will run on 110v. but the heaters require 220v. carfully remove small cover on back or if you have a outlet(wall plug) you must check for 220volt...PROBABLE CAUSE 1 fuse blown,,,, or bad circiut breaker. FIRST is there 220v. at plug This will tell us if it's a wiring prob. or dryer prob.
Mar 25, 2009 | Kenmore 62602 Electric Dryer
220v dryer plug
four wire plug straight slots are l1 and l2 bothe have 120 v0lts
l shaped is common rund shape is ground
Apr 08, 2008 | Dryers
220 lines
you have a 220v cord you want to installe into your , electric dryer.... easy enough look at your cord .. of the 3 terminal ends either end makes no difference which goes to the terminal block behind dryer. the middle wire needs to hook up to the middle terminal and then the last end goes to empty end terminal, AGAIN END TERMINAL CAN BE SWAPPED, THE MIDDLE MUST BE HOOKED TO MIDDLE, TERMINAL
Hooking an electrical dryer to a breaker
You will typically need a 40 amp 220V circuit for this ( check with local building inspectors).  You will need to run some hefty wire probably #8 three wire  (again check) and install the type of plug receptacle that is on the  dryer cord.
Inside the breaker box you will need a dual breaker 220V breaker rated at 40 amps.  The wire coming into the breaker box will need to be clamped in place with appropriately sized wire cable clamp where the enter the box through a knockout- available at any hardware store.
Now the big question-  why are you switching to electrical?  Gas is pretty much half as expensive as electricy  and will dry the clothes faster (usually gas dryers generate more heat than electrical ones).   Just wondering..
Oct 20, 2007 | Dryers
Dryers Logo
135 people viewed this question
Top Dryers Experts
