Question about Uniden CXAI5698 5.8 GHz Corded / Cordless Phone
How can i see the telephone # of recent calls,, i have a uniden corded with a cordless
  • 14 Answers
SOURCE: Uniden Cordless Telephone with Dual Handsets and Caller ID DXI-55
check if you have a manual. from there search up in the manual caller id settings. you have turned off the caller id option.
Posted on Nov 15, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
hmerchant110
  • 7191 Answers
SOURCE: Need Manual For Uniden Cordless Telephone Model #
You can download the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Jun 19, 2010
  • 8023 Answers
SOURCE: Need Owner's Manual for Uniden Cordless Phone Model 2180-3
Here is the link. to a pdf version of the phone manual.
Posted on Jul 31, 2010
How to turn on telephone ringer on base set for Uniden dect 6.0 corded
While the phone is in standby mode (not on a call or doing anything in the menu or message systems), press the up-arrow button.
If you need a manual, you may download a copy here.
Oct 10, 2012 | Uniden D2998 Dect 6.0 Loud/clear Big...
Uniden DECT1588 series blinking red light
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Sep 03, 2012 | Uniden Dect1588-5 Corded And Cordless...
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
How do I delete recently received calls ??
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual
Nov 05, 2009 | Uniden DECT 6.0 Cordless Telephone...
Just bought phone no dial tone i move the setting to pulse
First thing to try is another phone in the wall jack if it doesn't work either you need to call your phone company. If the other phone works, make sure that the telephone is getting power from the AC electrical outlet. Try swapping the telephone cord with another cord. and lastly, unplug the battery from teh handset and plug it back in untill you feel it click into place. Sometimes the new battery connections are pretty tight and may not really be connected even though it looks like it is plugged all the way in.
Mar 23, 2009 | Uniden 5.8GHz Dual Cordless Phone
Uniden Dect2080 with 5 cordless phones
phone appears to be on hold cannot get a dial tone on any of the phones what is the solution
Apr 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Uniden cordless phone
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
GE 5.8 ghz cordless phone
Get another telephone and connect the telephone cord from your cordless phone to it. If it works, then you know the problem is with your GE cordless phone. If it doesn't, try replacing the telephone cord. If still no good, call your telephone company.
Nov 05, 2007 | Uniden Cordless Phone
Uniden CXAI5698 5.8 GHz Corded / Cordless Phone Logo
145 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
