Question about Cub Cadet Garden
How do I level my mower deck?
How do I level my cub cadet mower deck?
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 69 Answers
SOURCE: I can not get my mower deck to turn when I pull
Your switch could be bad, or the voltage needed to turn on the PTO may not be up to par, or you may have a safety switch that won't let you start the PTO. I'd start with the safety switches.
Posted on May 11, 2009
  • 22 Answers
SOURCE: Electric clutch on my 4 yr old Cub Cadet 2518 was intermittent
check fuse or power it up seperatly with 12volts (battery directly into the two terminals) to see if it is a wiring fault but it sounds like you need a new clutch assembly $$$
Posted on Jun 20, 2009
lester482529
  • 226 Answers
SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
Posted on Jul 19, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Self propelled cadet mower locked up how to unlock
Check engine oil level first for proper level.If it has oil in it PULL SPARK PLUG WIRE OFF SPARK PLUG IF MORE THAN A SINGLE CYLINDER PULL ALL PLUG WIRES OFF. Put unit on its side and grab the blade and see if you can move it in either direction or if the engine is locked up.
Jun 11, 2014 | Cub Cadet Lawn Mower Deck Drive Belt...
982 cub cadet 3 blade w/ idler pulley deck belt diagram
hi there pauly 46 here
here is web site for streetsign cub cadet 982 46 " deck with 3 blades
http://www.partstree.com/parts/?lc=cub_cadet&mn=336+46%22+Mower+Super+Garden+Tractor&dn=0057000002
this shows deck belt routing
and here is website area for 982 parts break down for model 982 cub cadet
http://www.partstree.com/parts/?lc=cub_cadet&mn=982
take a look cheers hope it helps
pauly46
Apr 28, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1042 wuth 42" ower does not cut even. This is my 3rd cud cadet and theu all have cut unven.
There are just so many possibilities. I doubt this is specific to Cub cadet. Usually it is a result of a misalignment.
You can go here for some more information
Lawn Mower quality of cut
Dec 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do you replace the mower belt on a cub cadet?
check the alignment of the ideler pully to make sure it is even withe the drive pulleys. if not in line it will cause the belt to break. There is a spacer that is on the idler that should be on top and not on the bottom of the pully.
Apr 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
116 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
