Question about LG WM1814CW Front Load Washer
Not pumping water out
It will fill up and wash. but will not pump water out of the machine.
  • 159 Answers
Check the button trap,it is a flap door at the bottom of the machine somewhere.It's probably full of hair pins,coins or or other bebris.
Posted on May 31, 2010
I have dwf-170 mp washing machine, the machine does not fill with water.
that is not the water pump but the inlet valves are you sure the water is turned on behind the machine
Mar 28, 2016 | Washing Machines
Intermittently stops and starts pumping water
may have something blocked in the pump outlet valve
your washing machine will let out your water if you put your pump hose on the floor
Jun 23, 2014 | Fisher and Paykel Washing Machines
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Already took off pump & cleared out $12 in change but still will not pump all water out or spin out. can hear pump running but think the damage has already been done. would it be pump or pressure...
If the washing machine won't fill up, make sure that the water supply valves are turned on. Next, make sure there are no kinks in the supply hoses that run from the supply valves to the washing machine. If nothing is obstructing the hoses, you may have another controls issue.
Several of the washing machine controls are also responsible for the washing machine not draining, continuing to fill or filling too slowly. If the washer doesn't want to drain or stop filling, the issue could be the pressure switch. When water enters the machine, water also fills a tube in the pressure switch. When the air pressure reaches a certain point, it triggers a switch that will stop the machine from filling. Locate this pressure switch on your machine and look for damage. If you have a multimeter, use it to find any electrical issues. If there is no reading, the pressure switch needs to be replaced.
Read more: Tips to Repair a Washing Machine ' eHow.com http://www.ehow.com/way_5435622_tips-repair-washing-machine.html#ixzz1C6BhALK0
Jan 25, 2011 | Frigidaire GLTF2940ES Front Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
My ignis washing machine stops in the middle of the washing cycle and makes a sound, kind of blowing.
there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses.
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. This advice was originally written when most washing machines were hot and cold fill and didn't have error codes. It's now been updated to reflect the fact that these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
If your washing machine is stuck full of water the water needs to be drained out and this article gives tips on how to do this. If the entire washing machine has gone dead leaving the machine full of water it may be worth checking that it isn't something as simple as a blown fuse ( Washing machine is dead, wont start ) in which case if you get the washer going again it should pump the water out itself.
If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
Blockages are the more likely explanation, but pumps can fail.
Dec 31, 2010 | Amana NAV2330AW Top Load Washer
I have a fisher & paykel IW810 washing machine that will not fill the bowl with water. While filling, it is also pumping the water out, in the autowater level sensing mode. I have gone into the command...
hi, reading your posting it tells me that the machine will fill on traditional wash but on auto fill mode it pumps the water out at the same time it is filling. i"m pretty sure it is your diverter . on auto fill mode it fills a little bit then the pump comes on and recirculates your water by pumping the water from the bottom of the bowl to the top of the bowl over the clothes. on auto fill mode it also activates the diverter to pump the water back to the bowl. on your machine the diverter is stuck in the drain out position so when it trys to recirculate the water it drains out the water instead . the problem could be a faulty diverter, control module or a broken wire.hope this helps, please reply if you need more help. good luck.
May 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Machine does spin and fill but will not drain out water...at end of wash cycle there is still water in the tub. I tried unplugging and leaving it alone and then replugging nd at this time it acted as if...
The impeller in your water pump is broken. Be glad the water pump isn't leaking too or water would be on the floor. The water pump is usually easy to switch out; there is a clamp on each end of the pump holding the respective hose to the pump and a few screws mounting the pump to the washing machine frame. FIRST use a container to dip the water out of the machine, have plenty of towels to dry up the rest unless the machine can be moved outside before beginning the repair.
Aug 24, 2009 | Washing Machines
I have a problem with my washing machine..
Basic Washer Problems
No fill:
Bad water valve
kinked hoses
unpaid water bill faulty electronics. Overfill:
trash in water level switch tube
bad water valve
bad water level switch faulty electronics. Washes but don't spin:
bad lid switch
bad drive coupling or belt
bad motor faulty electronics Spins pumps but don't wash:
bad timer
bad motor
bad luck faulty electronics. Leaks:
bad hoses
bad pump
bad tub gasket faulty electronics. Fills washes but never advances:
bad lid switch
locked up pump
bad motor
bad timer faulty electronics. Goes through complete cycle but clothes soaking wet:
bad belt
bad pump
bad thrust bearing faulty electronics*. *electronics in appliances ****. My opinion.
Dec 28, 2008 | Washing Machines
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
LG WM1814CW Front Load Washer Logo
113 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
