Question about Maytag M7Y10F2A Air Conditioner
Turns on but no fan function
The electic digital panel works but the fan and blower do seem to work.
Is there a reset button??? or is it worse
  • Maytag Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on May 31, 2010
Carrier high efficiency furnace blower not turning when thermostat set to on position
is breaker and emergency shut off on-- check ---thermostat /operating correctly--gas /valve on--thermocouple /in working order--gas valve /operating correctly---reset ,high limiter,safety 's //are correct and not popped ---fan working order ---
Oct 25, 2016 | Carrier Heating & Cooling
Why is my fuel level indicator, heat control and fan blower, and radio not functioning? There are no digits: only flat lines. The speedodometer and milometer wokes but there is flashing around all t
These units are bad about cluster failures. If all fuses test good, cable to cluster is correctly attached, most likely the cluster needs repair.
Dec 25, 2014 | 1997 Cadillac DeVille
Acura legend ac control untied stop working along with the fans any idea wat could it be
The rotary control switch on the dash controls the blower motor for the A/C. The A/C will not turn on unless the blower motor is functioning properly. The passenger-side radiator fan will not turn on until the A/C begins running. BUT the driver's side radiator fan should always work. Ergo, check the function of the blower motor (located underneath the dash behind the glove box). Usually when it goes bad, it's because of the blower motor RESISTOR (mounted inside the blower motor housing). When the resistor goes bad, the blower motor shorts out, causing it to fail. The switch rarely ever fails. The radiator fan relays are located next to & on both ends of the radiator. Check them too. In the link, the blower motor RESISTOR is #5.
Acura Parts AcuraOEMparts com Genuine Acura OEM Parts from Delray Acura
Apr 02, 2013 | 1991 Acura Integra Hatchback
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
I have a walkman nwz-e345. Recently the volume has stopped working. I can turn the volume down all I want, but not up. When I reset it, the volume returns to a volume around 10 or 15. What can I do to get...
i have the same exact problem. the volume down button works ok. the volume up button seems to do any of a number of different functions other than turning the volume up again. it has just gotten worse and worse. christ damn i hope someone can figure out a fix.
Oct 19, 2010 | Sony NWZE345 MP3 Player
A/C and heater raddle/vibration when fan control turned on
That vibration is caused by something lying in the fan. This causes an imbalance in the fan that gives off the vibration. You will have to remove the blower motor in order to get to the fan and clear the fan of whatever is stuck in the fan.
Oct 06, 2009 | 2004 Chevrolet TrailBlazer
The climate control will not work properly ,,work intermitent .19
Blower motor control module probably , but without testing that's just a guess . Do you know how to do automotive electrical testing ? Testing B+ to the module ? Do you know where the module is ? You can find a wiring diagram here , http://www.bbbind.com/free_tsb.html There is a fuse for the blower motor in the I/P fuse box , HVAC blower 10amp ,
Mar 21, 2017 | 1995 Oldsmobile Aurora
I am having trouble accessing
It seems your blower is about to go out. Also you may want to check the relay on the blower fan just in case, if there's anything else I can help you please let me know, God Bless.
Willie
ECSracing Team
May 24, 2009 | 1993 Acura Vigor
Fan and compressor will not run
Try replacing the fuses for the condensor.
Apr 24, 2009 | Goodman CKL36AR36 Air Conditioner
Power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Jun 02, 2008 | Blodgett Ovens
Maytag M7Y10F2A Air Conditioner Logo
183 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
