Question about Dell 0Y3740 Keyboard
None of the keys on my keyboard work except the quick keys at the top of the board. It came back to life once, then did it again, ia it a cleaning/maintenance issue - or replacement issue?
  • 70 Answers
It could be a posibility that there is a virus. run a scan with good antispyware then try.
Posted on May 31, 2010
Keyboard stopped working, animal stepped on it.
Check the Num Lock key is not activated. If it is, press it to release it or you may have a jammed key.
Mar 05, 2014 | Dell Inspiron Computers & Internet
My KEY BOARD IS NOT WORKING
1. Restart your Computer at once. 2. If it doesn't work Turn off your computer and remove the keyboard from your computer and replace again. 3. If it doesn't work too, you need to change the key board. thanks
Aug 30, 2011 | Gateway 2520915 Keyboard
The keys: 9 / O / L / . are not functioning. all surrounding keys work for except these 4 keys is there something locked or is there a function key i can press to make them work?
These keys share a scan line in the keyboard. There is a break in the scan line or a bad connection between the keyboard panel and the controller circuit board inside the keyboard (or the motherboard in a laptop computer). Most keyboards use a pair of flexible plastic sheets with the scan lines printed in silver ink. These are attached to the controller with a "flexible printed circuit" connector. Sometimes the material tarnishes where it makes its connections there and the keyboard fails as you have described.
Most of these connectors have a friction lock that is disengaged by sliding it about 1 mm along the length of the flat ribbon cable going into the connector (there is a stop at this point - do not force the lock past it). The lock looks like a frame around the top of the connector box and has a slot for the cable. Once the lock is disengaged, the cable will slide out. Now you can clean the contacts on the cable (both sides) by polishing them with a white pencil eraser. When that is done, seat the cable back in the connector and push the lock back in until it makes a soft click or bottoms out on the connector shell. Once in a while there will be a connector that is friction fit - there will be no lock, but the cable will have a stiff reinforcing sheet attached to it. Very rarely, the lock will be a flip-up tab on the side of the connector - these are usually used only on smaller, narrower ribbons.
Avoid touching the circuitry on the controller board - it is easily damaged by static electricity.
If this doesn't work, you'll probably have to replace the keyboard.
Jan 06, 2011 | Dell 0Y3740 Keyboard
None of the keys respond
Hi
It seems that the connection of the keyboard is disturbed.
Check the TOP Lights which are on the key board. If the num lock is working then it shows key board is fine with the connection or check the connector
Tx.
Feb 19, 2010 | Acer NSK8458AN Keyboard
Computer freezes at sign up
i am planing to buy a hp desk top computor i want to know rates mean price
Apr 01, 2009 | Dell Dimension 4700 PC Desktop
Some keys in keypad not working
This generally happens in all notebook keyboards. The life of these keyboards are very short. I once had a Dell system which gave me the same problem. For that I removed the laptop case and reached its main board. In the main board, there will be a cable which connects the keyboard component to the mother board. It will be a thin ver very flimsy flat transparent cable which goes into a kind of slot of the main board. Remove the cable and reinsert again firmly. This may solve the problem. If not, then the keys of the keyboard would hav lost its life in such case you have to go for a new keyboard component from the manufacturer.
Mar 10, 2009 | Fujitsu AMILO Pro V1000 Notebook
Key board numbers and lights wont work
I would start by restarting the computer.
If this does not solve the problem you are more then welcome to get back to me and I'll see if I can help you to further solve the problem.
Dec 17, 2008 | Gateway 2520915 Keyboard
HP DV9000 ''G'' ''H'' and backspace keys seem to not work on occasion
Sometimes the simplest things cause us the most grief. A starting point might be to turn the laptop upside down (be careful!). Then, use some compressed air (Dust Off, etc) to blow the keyboard. If there is trash in the keyboard, you might just blow it out -- and fix the problem.
If that doesn't work, you might consider having the keyboard replaced. I normally take them off the laptop and hit them with compressed air from the back before replacing the keyboard. That's an option you should pursue only if you feel comfortable with minor dis-assembly of your laptop.
I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
Char1ieJ
Nov 23, 2008 | HP Pavilion dv9000z Notebook
The "i" key failed after a coffee spill. want to replace keyboard
No need to replace keyboard. If it really failed than none of the keys would work. Unplug it, turn it upside down, unscrew all the screws, open it up, clean top of he contact board with cloth dipped in alcohol. You can wash plastic parts and membrane manually in warm water with dish washing detergent. After that, wrap it in towel to dry. You can use a hair dryer but from a distance. Drying can take hours unless you work in it. Than just put all back together and screw back the screws. Plug in keyboard.
Apr 24, 2008 | Toshiba P000171240 Keyboard
Keyboard and touch pad locked
reboot- if that does not work the keyboard/touchpad may be disconnected or bad. ram is under an access panel on the bottom in the middle- you need a small screwdriver to add ram (ddr)
Nov 19, 2007 | Dell Latitude D800 Notebook
Dell 0Y3740 Keyboard Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
