Re: Ecosmart clothes washer When turned on with clothes inside, machine goes in to the mode of selecting water level, hunts back & forth in that mode for as short time and then goes to a long beep and nothing happens. Unfortunately I am unable to locate the user manual. Any ideas?
  • 11,896 Answers
You could have a faulty water level switch. I don't believe an unbalanced load would do this, a bad timer could do this. You can view entire diagrams of your machine on the partselect website.
I do believe the water level switch inside behind the drum may cause this.
Posted on May 31, 2010
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
About a week ago I noticed a puddle by the front of my washer. Now it is happening with every load, any size. It seems like the water is splashing up over the bucket and running down the inside of the...
Hi
In my opinion
This would be the water level sensor as the water should not get that high were it goes over the top the sensor should cut in and shut the water off at the level you set.
The problem can create more and can be dangerous as water and electricity not good best get it looked at.
regards Craig
Feb 01, 2018 | Fisher and Paykel WA37TG1 Top Load Stacked...
Washing not getting clean
ok, try this before you consider removing the bowl. 1st-- buy 2 pkts of bicarb of soda. 2nd---make sure machine has no clothes in it. 3rd-- empty the 2 pkts of bicarb of soda into the bowl. 4th-- select traditional wash mode , high water level, hot water fill. 5th-- push start. 6th-- let it fill and wash for about 5 to 10 min, then turn the machine off. DO NOT LET THE WASH CYCLE GET TO THE DRAIN OUT STAGE. ok now the machine is full water and bicarb of soda and turned off, LEAVE IT TILL THE NEXT MORNING.-- In the morning select traditional wash mode, high water level, hot fill , then push the start button. let it go thru the complete cycle and all the lint and dirt should be removed from the bowl. by the way once it has started to wash lift the lid and see if the agitator is working. good luck and please reply to tell me how you got on.
May 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel GWL15 washer won't drain. A latex backed rug was washed in it and I think the drain pump is clogged. How to remove drain pump and unclog it?
Hi There,You could bail out as much water as possible,Then If you lean the machine back against the wall,(with machine unplugged) you could remove the bottom plate (if fitted) and you will see the pump with a fan attached,Try turning the fan back & forth it may loosen the obstruction and you could then pump the water out before removing the pump for a service,A the front of the pump you will see a small plastic locking clip that needs to be held out while you turn the pump anti-clockwise for removel.Note treat everthing to be live on this machine if plugged in.(unplug machine before attemting any procedure) Best Regards.
Aug 21, 2009 | Fisher Paykel EcoSmart GWL15
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Need to set the washing machine for hot cycle, cold rinse
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
It really works!
Sep 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washing machine
The lid switch is bad on your washer. Either replace it or bypass it.
Oct 22, 2007 | Fisher Paykel EcoSmart GWL15
Open Questions:
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
