Question about Memorex MVT2135 13 in. TV/VCR Combo
I can`t get any audio. Its not on mute. I can turn the audio up and down on the screen
    President:
  • 1,099 Answers
First check that any muting control is not activated. This might be a button on the remote or set itself. If you have a headphone jack, it may have dirty contacts as plugging in a headphone usually mutes the speaker.
If the set is mono or only one channel of a stereo set is out, then check for bad connections to the loudspeaker. Test the loudspeaker by disconnecting one of the wires (with the power off!) and measuring its resistance with an ohmmeter (it should be less than 100 ohms - probably less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or audio signal tracer) and schematic. Or at least the part number off of the chip. Is the final amp a chip also or just a transistor? Have you tested the transistor? If there is little or no buzz from the speaker, that would indicate a problem fairly near the output. If the tuner/if were bad, I would expect some noise/hum pickup from the low level audio stages. Get the part number off of the chip. If it is in a socket, check the contacts for corrosion or looseness.
Hope it works...
Posted on Jun 01, 2010
Turn off mute
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
also right click on the speaker icon in the bottom toolbar (bottom of screen) you will have an array of options select either playback or recording devices then communications make sure the mute all sounds does not have a tick in the box.
Nov 26, 2013 | MSI Computers & Internet
My vm9224bt will not turn up or down
Review wiring diagram and check "mute" connection
Feb 16, 2013 | Jensen Vm9224bt 2din 6.2 Touch Screen Dvd...
I have an old Technics SA-GX300 receiver that works fine except that the screen indicates that muting is on (still produces volume but at much lower levels). I lost the remote to the receiver. Is there...
Reliance on the remote instead of walking across the room to touch the unit will not solve anything. On many receivers, Muting is cancelled if the volume knob is turned to a louder level. Try that.
There's a used original remote for $12 delivered on eBay right now.
http://cgi.ebay.com/Technics-RAK-SA301P-Audio-Remote-Tuner-TV-VCR-CD-/230644267386?pt=LH_DefaultDomain_0&hash=item35b378397a
Jul 08, 2011 | Technics SA-DX850 Receiver
I have a dell d520 laptop and it has no sound. Also I cant find the volume button. Where is the sound card placed?
The sound card is inside the laptop and is part of the motherboard. This means that you cannot take the sound card out and replace it.
You may need to reinstall the audio drivers for the machine but check first that the volume has not been muted. Look to the bottom right of the screen for an icon that looks like a speaker and click on that and see if it has been muted or just turned down.
If there is no speaker icon there it may have disappeared from the system tray. You can use your keyboard to turn the volume up or down and to mute and un-mute it.
The keyboard toggles are as follows >>>
To turn the volume up hold down Fn and press the PageUp key.
To turn the volume down hold down Fn and press the PageDn key.
To mute hold down Fn and press the End key.
It is also a good idea to check in the BIOS to make sure the on-board audio has not been disabled.
If there is anything else please post back.
Good luck and kind regards.
Apr 28, 2011 | Computers & Internet
How do I turn off the tv speakers so that I may use surround sound?
Depending on the model TV, there may be a switch on the back to turn the speakers off, or there may a choice on the audio on-screen menu to turn them off. Not all sets allow you to turn the speakers off, but you can always mute the sound, although this sometimes leaves the word "MUTE" on the screen to remind you. You can also just turn the volume all the way down on the TV. If you're using the AV inputs on the TV with a device like a DVD player, another option is to connect the video only to the TV, and feed the audio to the amplifier providing surround sound. Then the TV speakers won't be used at all.
Dec 01, 2010 | Philips Televison & Video
When I turned on my Toshiba tv today, it has no
Sounds like the speakers have died, it's muted at the source (cable box / satellite box if you have one) or that the cable for audio is loose. Check those three things starting with the last one and you will be able to pin point it.
Aug 11, 2009 | Televison & Video
"muting" shows up the screen and I no longer get volume, can not the muting off as I can not see where I would change that setting.
Are you sure it's not the TV telling you that it's muted? I went down the tubes on that one myself.
The receiver's Mute can be defeated by just rotating the volume knob upward. Ditto with TV's.
May 11, 2009 | Pioneer SX-205 Receiver
Volume wont turn down or mute
This can happen if you hook an external amp to the audio output jacks on the TV and those jacks are set to fixed output, but I will assume that you are talking about the sound through the TV's internal speakers. If the picture is normal and the On Screen Display (OSD) shows that volume is being turned down then the microprocessor is putting out the correct clock and data commands. You need to find the audio processor IC which controls the volume, tone, balance, etc. and see if the clock and data information is actually reaching that IC. If it is then I will bet that the IC is defective and needs to be replaced. If you do not have an oscilloscope or experience in repairing PC boards then have a qualified tech handle it for you.
Jul 11, 2007 | Quasar SP-2723 27" TV
Memorex MVT2135 13 in. TV/VCR Combo Logo
83 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
