Question about Fedders AEQ07FBG Air Conditioner
Fan motor want stay on - Fedders AEQ07FBG Air Conditioner
  • Fedders Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on May 31, 2010
Overheating, fan motor not running while engine is running. Need help in troubleshooting the control circuit.
Disconnect the ECT (engine coolant temperature) sensor with the key on, the fan should start in default and stay running, if it doesn't run check for voltage at the fan motor connector, if voltage is present and the connector is not burned looking or discolored replace the fan motor. If the fan has no power try jumping the relay socket to power up the fan motor circuit, if that works replace the fan motor relay under the hood. You gave no make, model or year and engine type so that is about all I can help.
Feb 23, 2017 | Cars & Trucks
The fan is not coming on and the refrigerator is not staying very cold
I assume you are talking about the freezer fan. The modern fan motors can just stop working. Remove the back panel and spin the blade. If it turns, the motor is probably bad. This would cause the entire refrigerator not to get very cold.
Jul 22, 2014 | Frigidaire Refrigerators
Fan stays on when i turn off my car,2006 ford fusion
What a pickle. How long did you give it before you disconnected the battery? You know, most fans may continue running for a short time, especially on a car that has been running at normal temperature for awhile. Reason being, the engine will actually get hotter for a bit as the coolant is no longer circulating. The fans shouldn't stay on too long. Most I have seen, less than a minute.
Be that as it may, a temporary solution to the problem, instead of disconnecting the battery to stop the fan-this is not good for the computer circuits who like steady voltage, however small-is to instead pull the fuse for the cooling fan. This is a large (80amp) maxifuse in the Battery Junction Box. The position in the box is F-29.
If it is staying on too long, the bad part appears to be a module or some type of relay-like switching device right at the fan motor itself. There are 3 wires to the fan assembly. One is the power feed from the aforementioned fuse, one is a command signal from the PCM to turn the fan on, and the last is a ground for the motor and assembly. I hope you could detach this device from the fan motor for replacement. Certainly nothing wrong with the fan motor itself. Good luck.
Jan 31, 2014 | Ford Cars & Trucks
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
Fan motor does not stay on
fan motor stays on when engine is hot.it means their is a triggering devise to make ON and OFF. if you are experiencing high temperature than the normal,cooling system has defect. you need to check radiator,radiator cup and the thermostat. thermostat is the devise that make your fan motor's work.
Dec 19, 2010 | 2001 Toyota Echo
THE MOTOR IS OFF THE FAN IS STILL ON
This is normal. The fan will run with the engine off till the rad temperature goes below about 100 degrees F. Do not worry about this only if the fan stays on longer than 10 minutes. You may need a new fan relay if it won't go off. Good luck!
Jul 13, 2010 | 1996 Ford Taurus
2001 Chev Cavalier blower fan intermittent
The power connection to the fan motor on these is known to overheat and cause a bad connection.The fan motor is above the passengers feet.Next time the fan motor will not come on, switch the selector to high and wack the bottom of the dash above the passengers feet.If the motor does come on at that time,you may need a replacement fan motor and connector.REPLACE the fan speed resistor board when replacing the fan motor,which is right behind the fan motor.
Apr 28, 2017 | 2001 Chevrolet Cavalier
Evap. fan motor stays on
Sounds like the control board is bad. Does the fan try to run when the tstat is off. Did you check the tstat. What kind of voltage are you getting at the fan motor. Did you check the capacitor. If you are getting voltage to the motor with no call for fan then the control board is bad. Let me know if you need any more.
Aug 19, 2009 | Carrier Heating & Cooling
Fan motor noise 2005 t bird
do you have a mechanical or a electric fan?
acording to your question seems to be electrical make sure the fan nut is tie and there is no cracks on blades
also wigle the ft shaft up and down and if you feel any play the replace the motor
Jun 01, 2008 | 2005 Ford Thunderbird
Fedders AEQ07FBG Air Conditioner Logo
44 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
