Question about Aiwa AV-D30 Receiver
My av-d30 was orking one day and the next day it wouldn't power on is there a fuse or breaker switch somewhere?
  • 75 Answers
There should be one either on the back of the unit or inside the unit on the C-board.
Posted on May 31, 2010
I have no power to my washing machine - fuse? Motherboard? Power point is fine.
the fuse in the plug has gone open circuit
check the circuit breaker in the fuse box of your home
sometimes there is a fuse on the plate on the wall
i think the pump is leaking somewhere around the hozes
blown a fuse or something similar
and you need to get back on to the engineer you payed
and get him to do the job right!!!!
Dec 08, 2014 | Washing Machines
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
How Do I Reset Circuit Breakers in 2006 GMC Envoy?
Hi Michelle, I'm glad to help!
Michelle, Sometimes there is a hidden fuse box inside the vehicle somewhere. It could be behind the glove box, in one of the kick panels next to your feet OR even on the side of the dash behind the cover. You'll need to check with the dealer and give them your VIN number and have them see if there are more then just the under-hood fuse box. Because most likely you have blown a fuse somewhere. You check on the fuses boxes and I'll do some more research and let you know. Hope this helps and have an awesome day Michelle.
Jun 04, 2013 | Cars & Trucks
Pontiac g6 drive the car a bit went somewhere got out came back 2 hours later all it did was turn over an wouldn't start has plenty gas left it alone for a bit try to start it it fired right up. So I...
flassed less engine power wth????????? Flashed reduced engine power ! Electronic throttle control problem ! Your best bet ,take it to a GM dealer , buick , cadillac , GMC . You do not have diagnostic test equipment or knowledge to even diagnose this.
Jul 06, 2017 | Cars & Trucks
Trigger siwtch spark cause electric short circuits
short in the ignition switch or loose wire at the ignition switch. if trigger switch is the key ignition switch you referring to.
Sep 02, 2012 | Cars & Trucks
I need an electrical diagram showing wiring from the base,to power windows on a 2003 Chevrolet Venture,my power windows won't work either side in my 2003 Venture,checked power at fuse box next to...
Check the main fuse box next to the battery, # 8 max fuse powers IGN MAIN 2 Ignition Switch to Fuses (I/P): BCM PRGRM, FRT HVAC LOW/MED BLWR, FRT WPR/WSHR, HVAC/DRL, MALL/RADIO/DIC, PWR QRT VENT, RR HVAC, RR WPR/WSHR, SWC ACCY & PWR WDO Circuit Breaker.
#3 circuit breaker is the front window breaker, try swapping it out with another breaker beside it and thats located in the side dash panel also.
The common cause of failed power window function is the switch on the doors going bad from dirt. Does the power window on the passenger side go down with the passenger side switch?? if it does then its a bad drivers side and and try cleaning the switch with electrical contact cleaner. 95% of the time this will save you from buying a new switch.
keep us posted and thanks you for using fixya
Nov 01, 2011 | 2003 Chevrolet Venture Passanger
JVC AV-48WP55 won't pwer up.
Start at the wall plug. Did a breaker trip for that outlet? Next use a multimeter to check voltage at the power input to the TV where the power cord connects to the mainboard. Be sure you are checking AC voltage. Next check DC voltage at the power switch on the inbound side of the switch. The power switch is usually after the transformer and AC to DC circuit. If you are getting power to all three places, check the other side of the on/off button. This will eliminate most of the power-related circuit. Also, look for blown capacitors, or burned areas around the power circuit.
Nov 28, 2017 | JVC AV-48WP30 48" Rear Projection...
Dryer is getting Power but not coming on.
Check the following---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 01, 2009 | Roper RES7646KQ Electric Dryer
Dishwasher has no power
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Don_humo
los parlantes no aguantan la potencia del equipo y hace saltar la proteccion del mismo apagandolo para no quemar el amplificador.
Jan 15, 2008 | Aiwa AV-D30 Receiver
Aiwa AV-D30 Receiver Logo
162 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
