Question about Olympus FE-210 Digital Camera
Why does my camera not take pictures sometimes then other times it works fine? it gives me a black frame.
Hi, I have the Same problem. Hope someone can help us out.
Posted on May 31, 2010
Black screen SL110
Sometimes it will help when you press the display button a few times. No display is one of the possibilities. But when the cable or the screen are defect, even pressing the button a thousand times won't help.
Success
Mar 02, 2015 | Canon PowerShot S110 / IXUS v Digital...
Light meter problems?
1: Make sure the exposure compensation dial (on the top left of the camera) is set to 0. You may be inadvertently moving the dial, which changes the exposure brighter or dimmer than what the camera thinks it should be. 2: If the auto exposure is set to center spot, then the camera will expose for the light at the center of the frame. So if there is a bright area in the center (a white shirt for instance) the camera will lower the exposure and the photo will be mostly dark. The opposite occurs if the center of the picture is a dark object.
3: Be sure not to block the light sensor on the front of the camera with your finger of camera strap.
4: Link to download the manual, in case you don't have it. http://support-sg.canon-asia.com/contents/SG/EN/0300419101.html
Oct 04, 2014 | Canon G12 Digital Camera
READ MENUS FINE, LENS OPERATES FINE, OTHER STORED PHOTOS READ GOOD, BUT CAMERA SHOOTS ONLY BLACK FRAMES, NO SCREEN IMAGES WHEN SETTING UP A SHOT. WHEN HELD UP TO THE LIGHT THROUGH THE LENS, A FAINT GRAY...
woowww man i think youv got a lot probs with you camera,mainly if there is a a black frame in you screen i think your screen monitor is damaged so ull have to replace it...... and da black frames is a fault in da camera itself.according to wot i understand i think the shutter speed is not corresponding with da software in da camera um sorry but dese repairs are gonna cost ya.... best tin is to give it to a repair shop or service personnel for further clarification
May 30, 2011 | Cameras
My ex Z1000 wont take pictures. i turn the camera on the lens goes in and out some times it looks like its going to let me take a picture and then the lens closes back into the camera and the screen goes...
your camera problem has the problem chance. Fisrt you should try with full charge battery. sometime weak battery cause also. Second main pcb does not resetting every time after taking picture. I hope you luck! Would you give more detail problem...
May 21, 2011 | Cameras
I gotmy new finepix camera in December. it works fine but sometimes when I am looking back at pictures I have taken it say read error and cant see the picture. what is the reason for this and can I fix it?
There can be two reasons for this problem.
  1. Might be your memory card is not working properly. Thats why reading or writing errors occurs most of the time. Try again by changing the memory card.
  2. Sometimes the data writing process of the camera could e malfunctioned, if so you have to give this to professional camera repair center.
Feb 28, 2011 | Cameras
How do I load my photos on a pandigital picture frame?
I could not load my directly directly from PC. I had to put them on my camera memory card, then insert memory card into frame. worked well but took more time.
Dec 29, 2008 | PANDIGITAL 6.0-Inch Digital Picture Frame...
BLANK (BLACK) PICTURES
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at http://www.dyxum.com/dforum/topic36109_post396839.html#396839).
However, if your camera experienced the FFB and then siezed (symptom 2) you can probably still get Sony to repair it free as its one charge for a complete camera repair. Call them up and tell them your situation.
Jul 23, 2008 | Cameras
My screen is cracked
The camera will still work fine. The screen is only for framing your pictures and reviewing them. It will be hard to take pictures that way. Just get a new camera. It will be cheaper than repairing the screen.
Dec 06, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
So much LCD trouble...screen is blank/black
CCD sensor fault ( not outputting anything so no pictures captured ). Have the sensor replaced but try to have it done free of charge. Sony does replace them free of charge but you have to check with them ( not all models with this fault are repaired free of charge ).
Sep 10, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Olympus FE-210 Digital Camera Logo
59 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
