F61 error I have a Panasonic SA-HT940 Home Theater in a Box. Recently, whenever I have the volume above a certain level, the player shuts off and displays the error message "F61". Not only can I not turn the player up loud enough to clearly hear dialogue on some discs, but whenever a sudden loud noise occurs (like a gunshot or an explosion) the error pops up again. This appears to be a common problem among this model of player. Panasonic has been absolutely no help, due to the warranty has expired (they directed me to an "authorized service center 2 hours away). What can I do to fix this myself?
  • 2 more comments
  • crawfordj Apr 08, 2008
    I checked, and my speaker wires are not frayed or crossed.
    I really appreciate your help. Would repairing this be something that I could accomplish by myself? What tools would I need? I ask only because there do not seem to be any repair shops around where I live (Western Virginia). I could eventually get it to a shop, but it would be much easier if I could just knock it out by myself.
  • crawfordj Apr 09, 2008
    Wow, I had no idea it would be that expensive. I think I'm going to demanding that Panasonic replace my player, as it appears that this problem is very common to this type of receiver. You have been a big help and I really appreciate it!
  • deze69 Jun 03, 2008
    when I turn it up above a certain level or a loud noise occurs it shuts off and reads check speaker wires
  • 4,234 Answers
If memory serves me correctly, the F61 message is teh shorthand for protect mode. There is a problem with the output section that is being detected. The unit shuts down to prevent additional damage to either the amp section or the speakers. I'll look up your specific model for more details. In the meantime, check the speaker wires to be sure that they are not frayed and crossed.
Dan
Posted on Apr 08, 2008
  • 2 more comments
  • ABRsvcs Apr 08, 2008
    Thanks for the update. This means that the problem is internal to the amp. I don't recall whether or not your model uses an amp pack. I'll check on that tonight. The output section will require repair. If it is just discrete transistors figure on $15-$25 in parts plus the local labor charge for repair. If it uses an amp pac (these are specific to Panasonic), then the parts cost could go up to $75,
    Dan
  • ABRsvcs Apr 09, 2008
    IF you are comfortable with soldering, you should be able to repair this. Open up the unit and look for large dark gray "ICs". These will be about 2 inches by 3 inches in size. If you have them, post here the numbers and I'll confirm the ones you need to replace.
    Dan
    I located the output amp pac. It is: RSN704D66 at a cost of $120 plus shipping.
    Dan
    Since yuo can hear some sound, the pac is not completely smoked. There is a possiblity that the supporting components leading up to the amp pac are defective. This would significantly reduce the cost, but there is still some time involved in finding the problem.
    Good luck.
    Dan
My panasonic sa ht930 volume when you give me presents on the screen and I f6 1 off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 18, 2011 | Panasonic sa-ht930 Home Theater Audio...
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Feb 22, 2009 | Panasonic Home Theater System System
Panasonic home theater sa-ht920
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Sep 17, 2008 | Panasonic SC-HT940 System
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic home theater SA-HT940
the best thing you do is set the region to ply coz some of the dvd player need to set the region
Mar 24, 2008 | Panasonic 600W DVD+VCR Home Theater System...
How do I solve Panasonic SA-HT800V error code F61?
unplugged a Panasonic HDTV plasma for four minutes, plugged back in and Now the DVD does not work.
How to reset?
Aug 28, 2007 | Panasonic sa-ht800V Home Theater Audio...
435 people viewed this question
 Grubhead
Grubhead
