Question about Honeywell Programmable Thermostat Heater
I am looking for instructions on how to operate a Honeywell program able thermostat that sets the temperature for cooling and heat
  • rtcapt229 May 31, 2010
    I believe the model # is Th6110d1021
  • 674 Answers
Need model #.
Posted on May 31, 2010
Tip
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that...
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that gives you electronic control of 24V AC heating and cooling systems. It also has the capability to be used on 750mV heating systems
One of the best features of this thermostat is it’s big clear backlit display. The current temperature, the set temperature and the time of day are displayed at all times. Simply touching the screen also activates the back light feature.
This thermostat has a menu programming guide the helps you through the process of setting up your schedule. You are able to select multiple days and customize the thermostat for any kind of unique schedule you may have. This thermostat also let’s you take it off the wall and still be able to program it. This lets you watch TV and program it at the same time.
There are built in backups that will hold the time for you if the power goes out. This t-stat will also update for daylight savings time. There are HOLD features that allow you to modify your program and hold it and then go back to the original.
Change reminders that are built in include the air filter, UV light, humidifier service and of course the batteries of the thermostat. The blower of you furnace can also be programmed to run extra to help increase the air quality in your home.
If you decide you want to know the outdoor temperature you can purchase an additional sensor and then hook it to you thermostat. The outdoor temperature will then be displayed on you thermostat. This feature also gives you the capability of using the sensor to monitor indoor temperatures remotely.
This thermostat will keep you very comfortable as the variation typically in temperature from set point is less than 1 degree F. The thermostat after a period of time learns the characterizes of the way the house or building heats and cools and then adjusts to get the most efficient operation of the heating or cooling system while maintaining a very close temperature tolerance.
By changing a few of the parameters in the thermostat this can be can be configured for either single stage conventional heat/cool systems or any single stage heat pump system.
Specifications of the Honeywell TH8110U1003 Thermostat
  • Description: VisionPRO Touchscreen 7-Day Programmable 1 Heat/1 Cool
  • Conventional and Heat Pump Thermostat
  • Application: Gas, Oil or Electric; Heat Pump; Millivolt
  • Programmability: Universal Programming from 7 Day to Non-Programmable
  • Changeover: Auto or Manual
  • Color: Premier White
  • User Interface: Touchscreen
  • Switch Positions (System): HEAT-OFF-COOL-AUTO
  • Switch Positions (Fan): AUTO-ON
  • Power Method: Battery or Hardwired
  • Terminal Designations: R, RC, C, W (O/B), Y, G, S1, S2
  • Dimensions (in.): 4 9/16 in. high x 6 in. wide x 1 1/4 in. deep
  • Mounting: Horizontal
  • Electrical Ratings: 20 to 30 Vac
  • Frequency: 60 Hz. 50 Hz
  • Setting Temperature Range (F): Heat: 40ª F to 90ª F. Cool: 50ª F to 99ª F
  • Setting Temperature Range (C): Heat: 4.5ª C to 32ª C. Cool: 10ª C to 37ª C
  • Differential Temperature (F): 1ª F
  • Differential Temperature (C): 0.5ª C
  • Stages: Up to 1 Heat/1 Cool
  • Outdoor Sensor: Yes, optional outdoor or indoor remote
  • Remote Sensor: Yes, optional outdoor or indoor remote
  • Sensor Element: Thermistor
  • Currents (Heating): 1.0 A running
  • Currents (Cooling): 1.0 A running
  • Currents (Fan): 0.6A running
  • Operating Humidity Range (% RH): 5 to 90% RH, non-condensing
  • Comments: Selectable to and Heat Only or Cool Only
  • Features: Screen lock
on Jan 15, 2010 | Hardware & Accessories
Tip
Th811u1003
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Specifications of the Honeywell TH8110U1003 Thermostat
on Jan 15, 2010 | Heating & Cooling
At what temperature do I program the thermostat for a comfortable cooling(at how much do set the cool and h ow much should I set the heat). Thanks for your help
Normal settings are heat 70 and cooling 74 to 76 I like 76 if your not active its fine. They say the every degree above 70 heat cost additional 5%.
Jul 02, 2011 | Honeywell Programmable Thermostat Heater
Directions to program cm 67 thermostat
How do I set one temperature for the whole day?
To operate as a simple thermostat with one temperature throughout the day, move the slider to the MANual position. Adjust the manual temperature by pressing the TEMPerature or button. The manual temperature can be set anywhere from 5°C to 30°C in 0.5°C steps.
Here is the User Guide for the CM67 Thermostat:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
May 17, 2011 | Honeywell Heat/Cool Thermostat
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
Nov 18, 2009 | Honeywell Electronic Programmable...
My thermostat has a .8 degree swing temperature
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Please rate my answer!
Mar 12, 2009 | Honeywell Electronic Programmable...
Program manual for honeywell thermostat model T8700C1005(1)
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Nov 13, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Pro 5000 wont bring Heat on
have you programed the tstat for your system? look at your installers book.
Oct 07, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
140 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
