Question about Med Lift Medlift 5500w Bariatric Power Recliner Liftchair
Where do you plug in the cord into the chair from the transformer? It came out and I can't find out where it goes to plug it back into the chair.
  • 177 Answers
Hi. I have had this very same problem in a customers house. It took a bit of looking.
Tip the chair over on its side a bit. Against the wall with a cloth to protect the wall, or get someone to hold it.
A torch or flashlight and a mirror will help.
The position of the socket will vary depending on the brand and model, but it will be there somewhere.
Good luck. Neil.
Posted on Jun 05, 2010
Solid yellow light on joystick controller will not light up and chair will not move. If we lightly shake the power cord several times that is located at the rear of the chair, problems corrects.
You have a faulty connection in the cord and need it checked. Disconnect battery and check the cord for the charging system for breaks in the cord wires and for a bad connection where it mounts to the transformer. If it is one unit you may need a new charger.
Aug 19, 2016 | Health & Beauty
I have a htt 9c chair. it was working yesterday. I went to use it today and it would not turn on. it has no power and circuit is fine. please help
First, check the power with a volt meter on the receptacle you are plugged into. (or plug a lamp into the receptacle and make sure it turns on. believe it or notI have seen this many times) If power is fine, then remove the back of the chair (with the cord unplugged) and stabilize the back of the chair as the wires hang from the back of the chair to the chair itself. Plug back in your chair and check power to the on/off switch on the back of the chair, if you have power there then it gets a little more complicated. Again, unplug the chair, remove the black plastic cover on the lower left of the chair that covers the main circuit board. You should see a soldered in fuse, use an ohm meter and check the fuse for continuity. If it reads good or "shorted" then you are past my knowledge in this matter. Hope I could be of some assistance.
Jun 28, 2011 | Interactive Health New Htt 9c Curve Track...
I bought a used m51 pronto sure step powerchair. The powerchair has no batteries or charger. I would like to buy a used charger and get batteries. Also where do you plug in the charger there seems to be a...
make sure it really doesn't have a charger ...
How,by taking that seat off,disconnect the joystick cable ,
take off the seat ,remove the black should which does or will cover the U1 Gellcell battery's you will have to buy. In the back of that chair there will be a box that has two cords one that pugs to the power cord( you'll also be needing to buy ,you can from radio shack if you don't have one that is)but the other wire connects to the model "'brain'' of the chair that's in the front of the chair. If its not there you'll need a on board charger,pluse two battery's and that power cable that plugs into the back of your chair ,It looks like and is the same as the power cable in the back of you computer.
Good luck hope I was of some help.
Jan 18, 2011 | Invacare Pronto M51 Power Wheelchair
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
What is the 3 prong outlet on the side of my chair for? Is it a charger?
If you have an on-board charger for your power chair this outlet is for your charger cord. One end of the AC cord plugs into the wall outlet and the other end plugs into the trapezoid shape outlet on the side of the chair. This is the same shaped AC cord used to power computers and other devices. You can buy one a most hardware stores and places like Radio Shack. If you are using an off board charger which plugs into the front of the joystick (round plug)to charge the chair, then you don't need to use the on-board one and you don't need another AC cord. Hope this helps.
Dec 04, 2010 | Jet 3 Ultra Power Chair
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
Human touch HTT 800 just beeping from back, not remote
Just had this problem with our HTT 800. Discovered it was the curled phone-like cord attached to the remote that had been chewed through by one of our dogs. Some electric tape fixed it right up. Still looking for a replacement. Anyone know where I can find one? A standard-size phone cord does not work with this, as it is too large.
Feb 27, 2009 | Interactive Health Ht 135 Massage Chair
Help my son has just snapped the white cable off his pyramax s1000 chair
I also purchased the chair and the white cannon plug goes to the white plug on the back of the audio on your t.v. as does the red to the red. The green plug on the otherside of the Y cable goes to the remote device and bo the chair and remote need to be set to the same channel.
Jan 04, 2009 | Pyramat Sound Rocker Gaming Chair
Med Lift Medlift 5500w Bariatric Power Recliner Liftchair Logo
100 people viewed this question
Top Med Lift Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Med Lift Health and Beauty Expert? Answer questions, earn points and help others
