Question about Plumbing
Blocked kitchen drain
Hi
We have a slow running kitchen sink, have tried products from supermakets to ''Clear bloked drains'' Still not difference — can anyone advise other options - short of a plumber
    President:
  • 1,902 Answers
If you have a wet dry vac, remove all the water in the sink. Then take 1 full cup of baking soda and 2 cups of white vinegar. Pour the baking soda into the drain, then pour the vinegar on top. Let it sit for about 20 minutes, then flush with scolding hot water. If that doesnt work then do it again and let it sit for longer. Baking soda and vinegar make a acid that will eat through most anything that goes down drains.
Posted on May 31, 2010
How do i clear fat from blocked kitchen drain
A cup full of costic soda crystals an the pour the contents of a boiling letting I top of it . Don't let the costic touch your skin it will burn , ( it will bubble and blow ) so move away after adding the hot water
Nov 13, 2013 | Plumbing
The water doesnt seem to be pumping away even though I can hear the sound of the pump
If water is not going away then it is likely the drain hose is blocked, the filter plate is blocked or the kitchen sink drain is blocked. check the garbage disposal unit if used in the kitchen sink has been operated and clear of rubbish before you operate dishwasher. Need make and model number of dishwasher to get a better idea.
Dec 10, 2012 | Dishwashers
Message on Model DWU9961 - Blocked Drain How do I
Hi wait a moment pls your request is been proceeding..
Jan 17, 2011 | Maytag Dishwasher
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
i thought I responded to this.
make sure the air gap in the kitchen plumbing (if installed is clear). Also check the kitchen drain is not blocked. If using garbage disposer in sink, then make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Water discharges out of the machine into the kitchen sink,when draining water from the sink its very slow to drain (maybe blocked waste pipe?) but now i realize the water is rising up to base of the drum...
Sorry to read about your problem, I hope this helps you out.
you have 2 different issues. Blocked waste pipe and a defective water fill switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Washing Machines
WHEN RUNNING A CYCLE ON TOP DRAW THE BOTTOM DRAW WILL FILL UP WITH WATER NOT DRAIN
The drain hose going to the kitchen sink is blocked. If you have an insinkerator in your kitchen sink then run it first. Otherwise take the dishwasher hose out from the sink outlet and run straight into sink to see if any difference.
Aug 17, 2010 | Fisher and Paykel 23 in. DD603H SS...
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
Jan 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Foul odor coming from kitchen sink/dishwasher area????
Hi Jenny - I had a terrible smell coming from under my sink, and I too thought it was a dishwasher/garbage disposal drainage issue. I used vinegar, baking soda, bleach and hot water on a daily basis. When I cut out the wallboard from under the sink and the smell got even worse, however, there was no sign of any water leaks or evidence of a dead animals. Come to find out, when I had a "friend" cut out a pass through from my kitchen (above the sink) into the den, he cut the pvc exhaust pipe and didn't re-route it nor cap allowing the fumes to escape outside via the attic. Thus, the fumes had no place to go other than down. The smell confused me because I thought it was rotten food or most likely a dead mouse trapped between the wall. The smell was actually causing me to get headaches. It's been almost 24 hours that this was repaired and I already can "smell" the difference. I hope this helps! Good luck.
Mar 30, 2009 | Tappan MDB531RF Dishwasher
Sink drain slow
You can purchase a device from Home Depot that will clean out the drain. In the plumbing business, we call it a blow bag. But some call it drain dog and so on. It's a black rubber bag that fills with water and then when it reaches a certain pressure it blocks the drain but runs water through it until the clog is dislodged. You attach it to a water hose and push it into the drain as far as you can get it. Run it for 15 to 20 min. and then pull it back out. There are several sizes to accomadate the pipe size. You sill need the one that does pipes up to 2 inches. You will have to remove your drain assymbly under the sink to do this. While you have the drain assymbly off, you can make sure it is clean as well. This will clean out the garbage that collects in the pipe. Hope this helps.
Mar 20, 2009 | NRS A.H. Undermount Large and Medium...
Plumbing Logo
261 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
