Question about Staples Arrow T2025 Staple Gun For Flat & Round Crown
I cannot move the finger shifter
Have arrow t2025
Shifter broke
Keep your fingers crossed that it is simply a loose pinch bolt on the shift arm. To check, look closely at the shift shaft end as you move the shifter up and down. If the shift shaft is not moving with the shift lever, the pinch bolt may be loose, or more likely, the splines have worn out on the shifter due to a loose bolt. To fix, grab a 10mm wrench and loosen and remove the pass-through bolt that is on the shift lever and replace the shift lever. I provided a link to a used one on eBay for $15. If the splines on yours are good and the bolt is tight with the shift shaft moving properly, then the internal shift fork is damaged which will require a teardown. 91 Kawasaki EL 250 EL250 Eliminator SHIFT LEVER
Mar 05, 2014 | kawasaki Motorcycles
Get into neutral w dead battery
next to shifter arm, is a small port, open and use your finger and press down, this will let you move the shifter to neutral
Dec 08, 2013 | Scion Cars & Trucks
Bought a "mont marte" handstapler and cannot find staples! 11.3 mm wide - 8 mm long and 1.2 mm fat! The last measurment is important, slimmer staples eject in two or threes in a twist! Can you help me?...
This is a stapler primarily for upholstering applications. Try inquiring at your local fabrics store or upholstering supply dealer. They may carry the staples. Unlikely you would find these at a hardware store but you could still try Lowes or Home Depot.
Oct 01, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
How do i fix the shifter on a 2007 chrysler 300 it will not go out of park.
Turn the steering left and right, it will lock your car in park or call dealership.
Sep 10, 2010 | 2007 Chrysler 300 AWD Sedan
Staples will not shoot flat. Have to hammer them
well most home hardware ones all do that if used on anything hard/heavy timber.....if it is a heavy industrial one it may need anew spring.
Jul 22, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
Putting the nails inside the gun
Here is the manual http://www.arrowfastener.com/upload/manuals/79055020257_manual.pdf
Eric
Jan 24, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
How do I open the darn thing to add staples?
Thanks for the link to the manual, fixyajohn. However, it wasn't clear on how to open it. However, the manual gave me the clue that it was simpler than one would anticipate when you first start grabbing at it. Just push in on the flat panel on the rear of the stapler. That disengages a little hook from the slot in the body. Then pull the released assembly downwards and finally rearwards out of the channel. Very simple. techmag's answer just doesn't apply to the T2025.
Aug 20, 2009 | Staples Arrow T2025 Staple Gun For Flat &...
Pokemon will Not Set Up
DO NOT breathe or move ur thumb/stylus after a few seconds it'll work
took me a while 2 figure out that it knows if u move or breathe
Dec 25, 2008 | Pokemon Mystery Dungeon : Explorers of...
Staples Arrow T2025 Staple Gun For Flat & Round Crown Logo
49 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
