Question about DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad
Looking for older TRANE RTU manuals
Looking for older TRANE RTU manual for MOD# SFCB-C176-HA
Operating manual for trane sfhc40
this is all i could find to do with what you are looking for so not sure if this link will help you out.
manual for trane sfhc40 Google Search
Dec 15, 2016 | Heating & Cooling
I moved into a home that has the Trane Comfortlink IIXL950 thermostat. How do I reset the pass code?
Pages 17 and 19 appears to indicate the password is your Wifi SSID passcode
http://www.bayareaservice.com/wp-content/uploads/2011/12/TZONE950-Owners.pdf
checkout the other pages for WEP support and other advance settings for multi zone and schedules
Aug 17, 2016 | Heating & Cooling
Manual
Ha ha ha. Problem with drill press, I need a manual. So go get one. Are we to guess what the model number is? Gawd, so lazy...
Jun 21, 2012 | Drills
Need specs for Apollo Mod.#AP72R
Try Googling (Apollo)(AP72R)(manual) without parens.
Aug 11, 2017 | Home
What is the age of the following Carrier RTU - Model # YCDO6OC460BF & Serial # R28105287D I have been told 1982, 2000 & 2007. The unit does not look that old, so do not believe it was a 1982,...
YCD060 is a Trane unit number not a carrier. Trane has a large guide for looking up approximate age of equipment. There is no date coded in the serial number, Trane does include a mfg date on most of the labels on later equipment, look for it on top or bottom corner of label if you can still read it otherwise I have the cuide at the office and will look it up this week. FYI our company is a TCS Trane dealer.
Aug 24, 2011 | Heating & Cooling
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
Tcp slave messages are not forwarded to rtu master
I think your last sentence there might be what the situation really is.  Your not getting a reply back. Maybe you should check the response timeout the gateway has set on it for the slave.  You probably already know a slave’s response time can fluctuate wildly depending on the nature of the request sent, so maybe the timeout setting is too short? Its a place to start. .
Aug 03, 2006 | Lantronix (200.2071)
DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad Logo
891 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
