Question about Dryers
220v dryer plug
I need to know where the wires go for my dryer plug
    Genius:
  • 1,073 Answers
Four wire plug straight slots are l1 and l2 bothe have 120 v0lts
l shaped is common rund shape is ground
Posted on Apr 10, 2008
How do I wire 110v from a 220v box?
You have two wires in the box that will read 220 plus
volts to the ground wire,the box if grounded & to the
white neutral
So pick one of those wires,(black or red ) for your short
recepticle slot & gold screw & the white neutral goes to
the silver screw & longer slot
Put a wire nut on the other 220/240 wire, if it isn't going to be used
Have to ID the breakers for the wires first & know what is on
those circuits.
Will need to change the breaker out if your running a dedicated
120 volt circuit & then you will have an open space you will need
a plastic cover for, when you remove the 2 pole breaker
Nov 18, 2014 | Dryers
Power needs for electric cooktop
red is for 240 volt. most dryers are 240. what does elec plug in look like?? like a regular 110 v plug? or a lot larger? if large plug its a 240 v dryer.
Mar 09, 2014 | Dryers
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
Sep 06, 2012 | GE Dryers
I just picked up a clean touch dryer and the cord is 220 the plugs in my house r 120 how and where do i connect the 120 cord
You cannot un a 220v machine on 120v
DO NOT change the wire on the machine
Have an electrician run a 220v line to where it's needed
Feb 08, 2011 | Whirlpool LGQ9858P Gas Dryer
The cord need to be changed from a 4 prong cord, 4 wire to a 3 prong cord, 3 wire 220V. which of the connections do i connect to?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 15, 2010 | Kenmore Dryers
Dryer getting hot but not drying
YOUR DRYER will start and run with only 110v. applied to it...........................How ever you won't get heat without 220v..........after you run dryer a few minutes you should feel HEAT inside.......my guess is you have no heat but the dryer runs,,,,,,,? If this is so, you probally are not getting 220 volts. you either have a blown FUSE or a bad circiut BRAKER in your main panel... remove cover (the small one) on back of dryer where the plug cord goes in....get someone with a voltmeter to check for 220v. going in to your dryer,,,,,,,,,,BLACK(wire) toWHITE(wire)=110v...........RED(wire) toWHITE(wire)=110v.........BLACK(wire) to RED(wire)=220v.............Let me know how you make out....P.S. don't go on ROOF..!!!!
May 11, 2009 | Whirlpool LER5636P Electric Dryer
KENMORE DRYER MODEL #96263800 WON'T HEAT
Need to know brand name and model#..........but it sounds like your only getting 110volts to the dryer instead of 220volts........The moter and controls will run on 110v. but the heaters require 220v. carfully remove small cover on back or if you have a outlet(wall plug) you must check for 220volt...PROBABLE CAUSE 1 fuse blown,,,, or bad circiut breaker. FIRST is there 220v. at plug This will tell us if it's a wiring prob. or dryer prob.
Mar 25, 2009 | Kenmore 62602 Electric Dryer
220 lines
you have a 220v cord you want to installe into your , electric dryer.... easy enough look at your cord .. of the 3 terminal ends either end makes no difference which goes to the terminal block behind dryer. the middle wire needs to hook up to the middle terminal and then the last end goes to empty end terminal, AGAIN END TERMINAL CAN BE SWAPPED, THE MIDDLE MUST BE HOOKED TO MIDDLE, TERMINAL
Apr 08, 2008 | Dryers
Hooking an electrical dryer to a breaker
You will typically need a 40 amp 220V circuit for this ( check with local building inspectors).  You will need to run some hefty wire probably #8 three wire  (again check) and install the type of plug receptacle that is on the  dryer cord.
Inside the breaker box you will need a dual breaker 220V breaker rated at 40 amps.  The wire coming into the breaker box will need to be clamped in place with appropriately sized wire cable clamp where the enter the box through a knockout- available at any hardware store.
Now the big question-  why are you switching to electrical?  Gas is pretty much half as expensive as electricy  and will dry the clothes faster (usually gas dryers generate more heat than electrical ones).   Just wondering..
Oct 20, 2007 | Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
