Question about Toshiba Televison & Video
I am trying to connect a Toshiba DVD/VCR combo to my television in order to play a DVD. What channel should my television be on?
  • abales27 May 31, 2010
    thank you so much
  • 8,197 Answers
To hook up your player you need to have the tv on chanel 3. If I can get the model # i can get you set up the right way so you do not need to change settings.
Posted on May 31, 2010
I can't connect my vcr/dvd combo to my HCT T.V
In the back of the tv their is goning to be a hole for the wire plug it in their
Mar 05, 2014 | Televison & Video
Want play from antenna
May just not be good enough antenna to receive the signal--try to with the remote direct enter a channel you expect to see and if it works you can in the menu add that to the memory---manually enter and add each possible channel.
May 01, 2012 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Connecting my VCR/DVD combo to Toshiba television
It would be helpful to know what cable your trying to connect, component, S-VIDEO, HDMI, etc. Also the make & model of the combo unit & Toshiba TV. However the basic process is usually the same for most hardware. Make sure the connection to combo unit is "video/audio out" not in and make sure the input for the TV says IN not OUT. Then you need to set the TV to the correct input channel. And then make sure the combo unit is using the correct output... usually this is automatic for component cables but not always.
Nov 16, 2011 | Toshiba Televison & Video
VCR shows tape is playing, but no picture or sound.
First, you need to check if the cables are properly connected to the television. Then you also check if you have your television on the appropriate channel that is to work with the DVD player/VCR combo for instance the AV channel. Then you can further try to change the cord used in connecting the DVD player to the television, if it does the same, then the problem is most likely from either the DVD's Audio Video port or from the Televisions Audio video port.
Have them both checked to detect which is faulty, and replace with the same type of port where fault is detected.
Take care and good luck
Oct 13, 2010 | Samsung DVD-V4600 DVD Player/VCR
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
DVDs are playing with green tinge
Greetings and Salutations,
If your using the component outputs from your DVD player I would first check to make sure that the cables for the Red and Blue channels are connected properly. If the cable is connected correctly then try replacing both the Red and Blue channel cable. If this fails to fix the problem try connecting to another component input on your TV if you have one available.
You might also want to check to see if you switched on the progressive scan switch on the back of the VCR/DVD unit. If you know someone with another DVD player have them bring it over and see if the problem is still exists.
If the green picture is still present then the problem is and internal problem with the TV and you will need to find a repair center for it. If the problem goes away then the problem is with the VCR/DVD combo unit. You can at this point also try using just the Video Out from the DVD player.
Hope these suggestions will help you with your problem.
Jan 06, 2009 | Toshiba SD-37VSR Player
Digital reception
If you do not have cable/satellite ,Yes
Dec 11, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
VCR plays tape with only sound and some channels seem deleted.
Needs the vcr heads cleaned, and get a universal remote with a menu button to change the tuner setup.
Jan 25, 2008 | Toshiba MV13P2 13 in. TV/VCR Combo
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Televison & Video Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
