Question about GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel
Fridge and freezer not staying cold. I have unpluged the fridge for 24 hours and then plugged it back in. The first few days the fridge and freezer were fine now it is not getting very cold again.
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerFridge and freezer not staying cold - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 31, 2010
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
Fridge is not keeping the food cold, water at the bottom of fridge, freezer is not as cold, still freezes things but takes a long time. This is a Kenmore 20 fridge, my guess is 15 years old.
unplug the fridge and leave the doors open for 48 hours, then see if your problem is gone 24 hours later after you plug it back in, if it is, your fridge needs to have a repair to the defrost side of things, most likely the defrost termination therm or the defrost timer, also make sure the drain under the evaporator is not plugged up
Jul 22, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
My freezer wasn't defrosting and the fridge wasn't as cold as it should be. I emptied it out and unplugged the fridge for 2 days and plugged it back in. Settings for freezer and fridge are on the highest...
hi how are you...please turn down setting to original setting from factory...in the freezer,does the back panel have ice on it....if so you have defrost problm...if not remove panel...if one one place on coil has ice ,but not whole coil...then has a freon problm....allow 24 hours for settings to readjust....hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...call if need assistance...good luck...
Mar 26, 2010 | Maytag MTB1956G Top Freezer Refrigerator
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
GE Profile Fridge/Freezer defrosting
You will need to replace the electronic mother board which is located in the back of the refrigerator,Inside rectangular cover near the bottom left.
Feb 28, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Fridge not staying cold
did you let the fridge stay in it's new place for 24 hours up right before turning it on?
Try turning it off for at least 24 hours and start it back up again.
If you moved it on its side the compressor oil flows into the lines and must beable to drain back down before using it.
If not you'll seeze the compressor.
not good.
Jun 25, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel Logo
98 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
