Question about Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player
The DEW light is flashing when I try to play a casette
The DEW light is flashing when I try to play a cassette. I tried drying the unit out and resetting the switch but the light continues to blink when I plug in a tape. There is no video at all. Nothing has been spilled on the unit. Is there anything else I can try?
3 Suggested Answers
  • 579 Answers
SOURCE: AUDIOVOX VCR SER#S9AA02677 MOD#AVP7000
That is 'dew' as in wet. Do you have it in a warm, dry location? This time of year they can attract condensation if the VCR is in a cold place.
Hope Ya Fix it!
Posted on Jan 06, 2008
  • 72 Answers
SOURCE: dew light is on vcr and will not play tape what
take a hair dryer on low setting and try to blow warm air into the vcr to warm it up until light goes out
Posted on Jun 11, 2009
Panasonic NV-DS27. Is there a manual eject mechanism - cassette won't eject.
try the casette eject lever located on the right side of the camcorder.has the condensation light come on? if moisture has gotten into the unit the casette may not eject. you will need to leave it for a few hours in a warm dry location for the unit to dry out and try again.
Hope this helps!
Tom
Jul 22, 2011 | Cameras
Dew light
Dew is likely to form in the following circumstances: ?When moving the camcorder from a cold place to a warm place. ?When placing the camcorder in a cold room which is then heated rapidly. ?When moving the camcorder outdoors from an air conditioned room or car. ?When placing the camcorder in the direct path of air blowing from an air conditioner. ?When placing the camcorder in a humid room. Dew will gradually form on the head drum of your camcorder and make the video tape stick to the head. This causes damage both to the head and the tape. When dew forms, recording and playback may not function properly. When ?DEW? flashes, remove the cassette,leave the cassette compartment open,and wait for a few hours to allow the camcorder to acclimatise to the surrounding temperature. To use the camcorder again, turn on the power after waiting for a few hours. Be sure that ?DEW? has disappeared. Do not insert a cassette while ?DEW? is flashing; this may result in damage to the tape.
Aug 03, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Theres something on the vcr yhat says DWE OR DEW and theres a red light flashing beside it when thats flashing it wont allow the movie to play what does that mean
the DEW light is a warning light. it indicates moisture on the tape. so make sure the tape is dry and in a ventelated area.
Mar 08, 2011 | Audiovox AVP7280 VCR
Videotape is at end of recording space. went to record new event and tape came out of casette and will not play or rewind in video camera
Try another tape in camcorder to make sure that camcorder is OK.
If same problem comes with another tape, check any error sign blinks in camcorder LCD? Usually this kind of problem happens when Dew sensor activated.
Remove battery/ power source from camcorder for 30-40 minutes, reattach battery / power source with camcorder and try.
Let me know model and brand of your camcorder for more research.
Thanks.
Oct 31, 2009 | Sony DVM60PRL/1BP Premium Mini Digital...
Shut down "dew"
This happens when you take camera from cold(er) environment to warmer environment, dew forms on the recording head, so as a precaution the unit locks up. The solutions is to leave the unit switched on and wait till the dew incator goes out( can take up to an hour) I found this out when on holiday, i would go from an air conditioned room to bright sunshine and it happened all the time.
Sep 28, 2008 | JVC Everio GZ-MG30 Camcorder
Camcoder
There have been several compaints about this dew issue. I recommend calling Sharp.
Support: (800) 237-4277
May 03, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Recording stopped working
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
Apr 26, 2008 | Canon ZR200 Mini DV Digital Camcorder
Dew and casette eject
With the dew indication, the tape will not load. This is to prevent the tape from getting stuck inside the unit. If "drying out" the unit has had no effect, either the sensor itself is bad or the connections to it are defective. Opening these is no simple task for the novice. Bring it in for service. It should not be more than about $100 to fix this problem.
Dan
Apr 09, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
HELP, my panasonic keeps shutting off. Dew? condensation?
Put it in a very dry place, and let it sit for a few days. How is it getting either dew or condensation? Once dried out, keep it in an airtight plastic bag.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player Logo
63 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
