Question about Comfort-Aire RAD-81 Air Conditioner
Full voltage present. does not turn on. is there
Full voltage present. does not turn on. is there a reset?
  • Comfort-Aire Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on May 31, 2010
The odometer is not working on my 1999 navigator. It just says 0. What could be the problem?
Odometer The instrument cluster receives odometer rolling count status from the PCM-engine computer and stores the mileage in non-volatile memory (NVM). When the instrument cluster fails to receive the odometer rolling count status for more than two seconds, the odometer display will show dashes.
HEC Dealer Test Mode
To enter the HEC Dealer Test Mode, depress and hold the instrument cluster SELECT/RESET button and then turn the ignition switch to the RUN position. Continue pressing the SELECT/RESET button (5 seconds) until tESt is displayed in the odometer. The SELECT/RESET button must be released within 3 seconds of the odometer displaying tESt to begin the dealer test mode. Depress the SELECT/RESET button to advance through the following steps until dtc is displayed. Depressing the SELECT/RESET button will display any continuous DTCs stored before proceeding to the next step.
All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster .
Odometer Display Description GAGE Activates gauge sweep of all gauges, then displays present gauge values. Also carries out the checksum tests on ROM and EE. If the gauge sweep is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster . All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster . bulb Illuminates all micro-controlled lamps and LEDs (low oil pressure/high coolant temperature, low fuel, service engine soon, brake, low range). INSTALL a new bulb or LED as necessary. r Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline). If alternating flashes of FAIL and ROM level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster . EE Displays hexadecimal value for EE level (used when requesting assistance from the hotline). If alternating flashes of FAIL and EE level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster . dt Displays hexadecimal coding of final manufacturing test date (used when requesting assistance from the hotline). dtc Displays continuous DTCs. Pressing the SELECT/RESET button will display any DTCs stored before proceeding to the next step. enG Displays the English speed in mph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0. m Displays the English speed data (mph) received from the PCM via SCP Network. Displays the metric speed in kph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0. tAc Displays the tachometer data received from the PCM via the SCP Network. Tachometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if engine rpm is 0. FUEL Displays the actual A/D fuel level. The fuel gauge will display a filtered fuel level value. This filter will keep the pointer from moving suddenly or erratically. If the value displayed is between 0 and 20, the circuit is shorted. GO to Pinpoint Test D .
  • 255=open send +/-0
  • 232=Full stop +/-10
  • 215=Full mark +/-10
  • 178=3/4 mark +/-8
  • 138=1/2 mark +/-7
  • 93=1/4 mark +/-5
  • 41=E mark +/-4
  • 54="LOW FUEL" (0-59)
  • 0-18=short (0-20 max.)
OIL Displays the code (0-255) for the oil pressure switch input to the HEC. Displays the oil pressure reading input to the HEC. Oil pressure gauge will indicate present oil pressure. Normal oil pressure (greater than 6 psi) will display a value between 000 and 176. A low oil pressure (less than 6 psi) or an inoperative engine oil pressure switch will display a value greater than 176. dEGC Display of engine temperature in Degrees C input from cylinder head temperature sensor. If the value displayed is -40C, the SCP message for engine temperature has not been received for more than 5 seconds. GO to Pinpoint Test E .
  • 49 C="C" mark.
  • 60 C=Normal band start.
  • 120 C=Normal band end.
  • 119 C=Temperature warning indicator ON.
  • "-40" C=No SCP Message for 5 sec.
br Displays the brake fluid level input to the HEC. bAtt Displays the code (0-255) battery voltage input to the HEC. Battery voltage gauge will indicate present battery voltage.
  • 93-102=6.9-9.1 volts (Low voltage)
  • 115-124=8.5-10.7 volts (Norm band start)
  • 215-225=15.8-18 volts (Norm band end)
  • 230-241=16.9-19.1 volts (High voltage)
rhEo Displays the present hexadecimal value for the instrument cluster backlighting pulse width modulated (PWM) input to the HEC (used when requesting assistance from the hotline). rhi
rhS
rho PWM input duty cycle.
SCP hexadecimal dimming step (used when requesting assistance from the hotline).
Output driver counts in hexadecimal format (used when requesting assistance from the hotline). Cr Displays the present RUN/START sense input. Display will show -h with the ignition switch in the START position and -L with the ignition switch in the RUN position. ALtF Displays 8-bit hexadecimal value for alternate fuel level. Display will show a value between 00 and FF if the message is received. PA-PE7 Not used. GAGE Repeats test display cycle.
Turn the ignition switch to the OFF position or press and hold the SELECT/RESET button for 3 or more seconds and release to exit HEC Dealer Test Mode. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Mar 12, 2018 | 1999 Lincoln Navigator
2008 h d rode king gas geage flasing emty (TANK FULL)
For a 2008 Touring bike with the ignition switch turned to IGNITION the fuel gauge is connected to +12 volts. Current flows through the gauge and the variable resistor in the fuel gauge sending unit to ground. The sending unit float controls the amount of resistance in the variable resistor. Inoperative gauges may be caused by several different circumstances: the sender or fuel gauge may not properly or sufficiently grounded; there may be a malfunction in the sender or in the fuel gauge; there may be a broken or disconnected wire from the ignition switch to the fuel gauge; there may be corroded connections at the fuel gauge.
Test the fuel gauge system by FIRST removing the gauge, THEN ground the fuel gauge sender Y/W wire located at the bottom of the gauge, turn the ignition switch to IGNITION and the fuel gauge must indicate FULL in which case it is functioning correctly in which case set a multimeter to the RXI scale and measure the resistance of the sending unit by placing one probe on (Y/W) and the other probe on the motorcycle ground or bare chassis point as a ground. If the fuel tank is full the reading should be 30-50 ohms while an empty tank should have a 240-260 ohm resistance value and a half full tank will be approximately 125-165 ohms. If a very high resistance or infinity is indicated on the meter, the sender may be "open" or not grounded. Check that the sender and the fuel tank are both grounded by placing one probe of a Multi-Meter on the sender flange and the other probe on the engine crankcase. The meter then must indicate one ohm or less. Replace the sender if one ohm or less was present and if a higher resistance is present, check for a poor connection on the ground wire.
If when the gauge did not indicate FULL when the fuel gauge sender Y/W wire was grounded with the ignition switch at IGNITION check the voltage to the (O/W) (+) and (BK) (-) wires of the fuel gauge connector and a correct reading will be equivalent to battery voltage. If battery voltage is not present check for a broken or disconnected wire. Replace gauge if wiring problem is not foun
Apr 16, 2014 | 2008 Harley Davidson FLHRC Road King...
Turns on but do not hear water going into dishwasher
Possible that the inlet valve is blocked at the filter end. You will need to check the voltage to the inlet valve,if present without any action then the valve is choked or faulty.- try to clean and reset.
If there is no voltage then the program controller unit is faulty.
Mar 16, 2011 | Bosch Integra® 500 SHX46A0 Dishwasher
Robinar Cooltech 342000 - on start up stops on the "Initalizing System" screen. Is there a reset procedure available?
You can try the following : 1# Check main 15 amp circuit breaker (located on back of the machine), reset the circuit breaker. If breaker tripped again after reset, the circuit breaker need to be replace.
2# Verify line voltage is present at input of main power switch & output at switch turn ON. If line voltage is not present at power switch input, check connections between power switch and AC plug. If line voltage is present at power switch input, but not at output with power switch turned ON, replace power switch.
3# If all proceeding steps tested OK & problem still exist, you may nee to replace The main control module.
Hope this will help you, if so please vote for it.
Mar 07, 2011 | Robinair Cool Tech 34700Z Recovery,...
Our Robinair a/c recovery machine has power to the switch, but will not power up at all, any ideas?
Please do the following : 1# Check main 15 amp circuit breaker (located on back of the machine) it may tripped, reset the circuit breaker. If breaker tripped again after reset, the circuit breaker need to be replace.
3# If all proceeding steps tested ok & problem still exist, you may nee to replace The main control module.
Jul 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
Should voltage be present at the terminals for the upper element with the element turned off? the element burned out. i have 20 to 24 volts at the leads with the element off.
yeah you might get some voltage through the switch when you switch on the element you should get full voltage 230v if element does not heat change it
Aug 22, 2009 | Ovens
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
My dual xdm6820 doesnt turn on and theres a red binking light behind the face plate next to the reset button
Probably you are mising 1 voltage,check this you need to have 2 voltages ok,1 voltage has to be present on the yellow wire(constant voltage,means all the time,ok) and the second voltage on the red wire (this voltage has to be switched wiht the ignition key)check this and try to fix the problem,probably there is a fuse blown,you can use a tester light to check the 2 voltages.or if you dont want to do this just conect the yellow and red wires together and the unit has to turn on.
Mar 24, 2009 | Dual XDM-6820 CD Player
My car has a full charged battery and when i turn the key on to start the car all the dash lights come on like they are supposed too but the car does not turn over.
Try to start it in neutral. If it starts you have a bad neutral safety switch. If it doesn't use a 12 volt test light to check for voltage at the small solenoid wire at the starter while someone holds the key in cranking position. If voltage is present you have a bad starter. If no voltage is present check all battery connections and starter relay.
Dec 28, 2008 | 1995 Dodge Intrepid
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Comfort-Aire RAD-81 Air Conditioner Logo
125 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Cesar Quant
Cesar Quant
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
