Question about Brother HL 1440 Laser Printer
Power spike When the printer goes from "Sleep mode" to "Ready mode" a power spike is generated that causes the computer to crash. Is there a way of preventing the printer from going into "sleep mode"?
  • 589 Answers
It sounds like you have some serious wiring issues within the building / house you are in, and voltage is being sent back through ground when the printers fuser goes into warm-up.
A line conditioner / stabilizer may help, but honestly, I would call an electrician before it completely shorts out the computer, or burns the house down.
Posted on Apr 08, 2008
Lenovo idea pad 300 won't turn on. Red power light blinks 3times then switches off. Rebooting doesn't work. Tried different adapter. Power on Lenovo screen appears for 5 seconds then goes black.
Sometimes they 'crash' in sleep mode. Try hold the power button down for 10 seconds. This should make it reset. After the 10 seconds, release the power button. Then press it again to turn it on normally.
Oct 09, 2017 | Lenovo Computers & Internet
Power save mode sleep
Hi Brian,
The printer goes to sleep mode irrespective of what cartridge you have in the printer. Printer goes to sleep mode if the printer is not in use.
Regards,
Sean
Jun 04, 2013 | HP LaserJet 5500 Printer
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
Hp M2727 goes into low power sleep mode and can only recover by cycling power
You may need to have your printer's firmware updated by a certified technician.
Jun 08, 2010 | HP Laserjet M2727nf Multifunction Printer
Monitor works fine until the sleep mode and then it goes blank. I have to unplug the power button and it does work again
It seems it is a motherboard battery problem. It most likely is not the monitor which is in "sleep mode", it is the computer itself.
When you cannot get a computer out of "sleep mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty. When your computer detects this battery is empty, it goes into a low-power mode. The solution is to replace the button-cell battery on the motherboard of your computer
If this solution works fine for you please rate this
Feb 24, 2010 | Dell E196FP 19" LCD Monitor
Computer will not go into sleep mode
External drives (hard drive, DVD burner, iPod, USB drive), printer, a worn out mouse button, debris in/on the keyboard, and cats are all things that can cause your computer to refuse to sleep (or wake it shortly thereafter).  Rule out these first.  I have had the same problem in the past.  It is almost always one of these that causes the problem.
Feb 23, 2009 | Apple Power Mac G4 Desktop
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Won't turn on
More than likely the power supply has defective parts, and or some other modules have failed.
Using a generator to direcly run a Plasma or LCD screen, and most any high end equipment is very dangerous for these. They are very critical to the quality of the electric power feeding them. If the AC frequency goes too far off specs, or there are noise spikes or distortions in the sinewave structure of the AC power, this can cause damage.
If you have a very high quality generator with very good power conditioning, frequency stabilization, and voltage regulation this would be the proper way to go.
Jerry G.
Apr 30, 2008 | Televison & Video
Brother HL 1440 Laser Printer Logo
160 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
