Question about Tomtom ONE 130S Car GPS Receiver
Won't turn on
I plugged the unit into the receptor as in the past, but it would not turn on.
The LED on the plug was lit as was the LED on the bottom of the unit.
    Brigadier General:
  • 4,090 Answers
If it went completely flat it needs somne recovery time to get a decent charge in the battery to start up.
If after a few hours it hasn't started up then change the battery for a new one as that one has died.
Please rate my help++++Thanks for using FIXYA
Posted on May 31, 2010
Wont turn on
follow this steps and fix it.God bless you
There is something blocking the receptor on the main unit.
Remove any obstructions and clean the area in front of the receptor.
The remote is too far from the receiver or at too extreme of an angle.
Move closer to the receiver (within 23 feet) or change the angle (within 30 degrees) to the receiver.
A fluorescent or other bright light is shining on the receptor on the main unit.
Turn off the light or shield the receptor.
The device has a keylock or lockout feature turned on.
Check the display for a key or lock symbol, then follow the instructions in the device's user manual to turn off the keylock or lockout feature.
Either the remote or the receptor on the device is not functioning.
Use an Intraed Sensor to see if the remote is sending a signal.
If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
If the remote is not sending a signal and you have replaced the batteries, you will need to repair or replace the remote, depending on cost.
Jul 26, 2013 | Televison & Video
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Sep 06, 2012 | Whynter (WC16S) Wine Cooler
Proscan 42LA45H 42 in. LCD TV won't turn on, no red led when plugged
The power supply is the most likliest cause of the issue. You can get replacement power supply from www.tvcircuitboards.com
Mar 02, 2012 | Proscan 42LA45H 42 in. LCD TV
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My LG washer won't turn on. When I press the power button, you can here the power on jingle but the display does not turn on and when I turn the cycle selector nothing happens. This a fairly new washer a...
replace the main control unit under the inits top cover in the left rear top corner & inside the plastic cover if when you open the cover that protects the mainboard from water spray(if theres NO RED LED lit on the control board) then its the board that needs replacing,if it has the LED lit then run the diagnostics per the tech sheet located inside the machine and it will tell you whats actually wrong,next step is to replace the touch pad located around the selector knob on the front face of the unit
Jan 27, 2011 | LG WM2077CW Laundry XL Front Load...
Won't turn on
The 330 series don't have an on button (they are on all the time, unless you unplug them), so presumably you are saying it is plugged in but the light is not on, the button on the front doesn't respond, and it doesn't print.
I'll assume that you have checked that the power supply is plugged in to a known working power socket and the socket is switched on if applicable (depends on country), and that you have checked the power cable is firmly plugged into the labelwriter.
Check to see if the power supply has an LED on it. If it has but it is NOT lit, and is definately plugged in then it is probably a dead power supply (or possibly a blown fuse).
In this case you can try a replacement power supply: Dymo LabelWriters (2nd item from bottom)
If the LED is lit then it would suggest that the labelwriter is broken.
Oct 08, 2009 | Dymo LabelWriter 310 Printer
No Sound from JBL On-Stage 400
The power supply consists of two parts: the AC cord with a two-prong connector on one end and a double barrel plastic connector; and the large rectangular power supply which has a dual prong receptor on the side and a long cable which plugs into the JBL unit.
In my case, I had plugged the double barrel plastic connector into the dual prong receptor backwards. Even though I was getting full power to the unit, this somehow caused the speakers to become inoperative.
Of course, I would offer a recommendation to JBL that their power supplies are made to be "dummy proof" so this does not happen to others as well.
Jul 29, 2009 | JBL On Stage Micro Portable Speaker Dock...
TV turns on and off by itself
  • Try replacing the batteries in your remote.
  • Cover the infra-red receptor in front of your TV to see if you’re getting unwanted signals from the receptor; covering the receptor with a bit of foil should do the trick.
  • Have you recently added equipment that might interfere with your TV’s operation—like a remote control extender or a new device for your audio-video system? Remove these devices and test the TV.
  • Feb 16, 2008 | RCA F36665 36" TV
    Tomtom ONE 130S Car GPS Receiver Logo
    Top Tomtom GPS Experts
    k24674
    Martin Murray
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
