Question about Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and
Cannot get the old cartdridge out of the single handle delta faucet in bathroom It drips and i want to change the cartdridge
    Scholar:
  • 81 Answers
If you indeed have the original T13420 trim, the replacement cartridge in RP46047. This trim should have a solid lever handle which should have an access hole directly beneath the one piece handle itsself. It might have a decorative plug in it. If so remove it with your fingernail. Be sure to put a cloth over your drain so iff you accidentally lose control of it you wont lose it. Insert the appropriate sized hex wrench and loosen the handle setting screw until the handle can be removed (a multi hex wrench set usually works). Grab the decorative chrome tube behind the handle firmly and pull. You will now see the top of your catrtige and just behind it a large round locking collar (RP22734). Firmly grab it and turn counterclockwise untill it now comes off. You can now remove the cartridge. Often it is easier to do this at this point be reattaching the handle and pulling on it. There are ways to adapt to The t13420 trim which requires a different cartridge so besure to take your old cartridge with you to your parts house. See the following links for parts breakdown.
http://www.deltafaucet.com/customersupport/documentation/T13420-SHC.html?document=pd
http://www.deltafaucet.com/customersupport/documentation/R10000-IP.html?document=pd
Posted on May 31, 2010
The faucet drips constantly from a single handle tub. How do I fix this?
we would need a little more information but sounds like it will need replacement, The water will eat up the meatle and make a rebuild impossible sorry but no quick fix the hot water lineis usley the culprit
Aug 09, 2017 | Plumbing
My bathroom sink faucet has a slow leak. I cannot determine the make or model number. It is a single handle, 11 years old. The cover for the set screw ( on the handle) is red and blue, like American...
delta also uses red and blue,, but its fine, remove the insert and take it to any home improvement store, they will be able to match up the sleeve, if its just a slight drip, you can just replace the bottom washer and faucett seat,, if its a single handle you may have to get the kit that includes the O rings to rebuild it,, be sure and get some plumbers grease when putting it back in,, especially lube the O rings as they usually give out first
Jul 23, 2011 | Plumbing
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
How do i install a new cartdridge for a delta single handle faucet in my tub
Remove the shower control handle. If the cartridge is threaded there will be a nut on the top. Remove with a crescent wrench. If there is no nut then there will be a retaining clip and the cartridge will then pull straight out. Installation is the reverse procedure.
May 31, 2010 | Delta & Single Handle Shower Faucet
How do I replace a single handle Delta mixer??
You would have to open up your drywall, cut and re-solder a new single handle faucet. An easier approach could be to shutting off your water supply, draining the lines in your bathroom from someplace below, and then trying to fix the bad soldered joint if you know how to do so.
I hope this helped.
May 25, 2010 | Delta & Single Handle Shower Faucet
Leaking bathroom faucet
These single handle faucets tend to need the internal "O - rings" changed every couple of years. Find your model # and take it to Home Depot or Lowes or some similar store and find the "kit" compatible with your faucet. Some kits have a cartridge, some have springs, O - rings, etc. The kit will have instructions on how to remove tha old one and install the new one.
May 24, 2010 | Delta Model 470: Signature Kitchen...
We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Logo
226 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
