Question about Car Audio & Video
I have a 15inch kicker cvr sound comes out great but when the bass hits it rattels is there any body that can fix it
    President:
  • 1,902 Answers
You can fix it, there is a pretty easy fix with speaker until you can buy a new one. Take some old news paper and some glue and glue the seems with the newspaper. you will want to use roughly about 6 strips per section that is broken, make sure that you are using super glue and everything is correctly glued
Posted on May 31, 2010
BOse lifestyle 12 Series 2 Bass Module Front panel ratteling how to fix?
happy to help . well its a classic case of over tightnening the screws on the body of the speaker and then it cracks and the ratteling sounds starts coming or they r loose . just glue it down with super glue or tight them as required.
Nov 30, 2014 | Bose Audio Players & Recorders
I have a kicker sx650 powering two kicker cvr 102 at 2ohms but i havve no clue on where to set the settings at and i know this amp should make these subs pound. i need to know exactly what to put each...
How I tune:
turn amp all way down or disconnect rcas for now, turn up stereo to a song with some bass you listen to and crank it as loud as you would (not max about 3/4, use this to tune inside speakers (don't have bass maxed/distortion...)). Now dial in amp: turn up a bit probably to 1/4 or so then tune frequency I'd usually say around 100hz, then adjust gain again to where it sounds good...be easy on them for awhile to let them break in (don't blast them all day!). Usually bass boost is only 1 frequency with a curve (40hz or something)...so I try to not use it much....
Apr 25, 2014 | Kicker Car Audio & Video
My (2) 12 in kicker cvr subwoofers are connected to a 3000 watt amp in a ported box. Once I turn my music up sofa they sound distorted how do I fix this problem
turn down the gain and the preout in the head if it supports it. also turn down the frequencey to 80. also dont over shoot the speaker by turrning up the bass on the head unit and then turning up the volume.
Mar 08, 2011 | Kicker CVR12 Car Subwoofer
How to hook up two 10" kicker cvr for best sound
If they are single voice coil and are 4 ohm you can bridge your amp and run both speakers off of it so your amp sees a 2 ohm load....better bass that will hit harder....(series wiring) look it up on google....
Sep 25, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
My subs sound distorted and dont pound right 2 12in cvr kickers and a kingwood 2 channel amp think its not wired right
Are you sure the polarity is correct on the sub's connectors? This is very important as reversing them will cause the sub to pound inward instead of out. Make sure the wires are thick enough and that the amp's + connector goes to the red(or +) connector on the sub and that the amp is grounded properly to a clean piece of metal on the car's body. This ground wire should also be as short as possible. Also make sure the fine-tuning for the bass level on the amp is adjusted correctly and that the sub's enclosure is the correct specification ie. Ported or sealed, right size, etc.
Mar 09, 2009 | Kicker CVR12 Car Subwoofer
Bass 2 powerful?
yes will definately blow them you need bigger speakers! im stuck on ma audio subs great wattage for the price ! and shake hard!
Feb 26, 2009 | Car Audio & Video
2 12'' cvr kickers
ya u allreadyfound ound out the problem u have factory amps there u go after market
Feb 27, 2008 | Kicker CVR12 Car Subwoofer
My kicker amp turns off
It sounds like you may have the load impedance too low. How many voice coils per woofer? How many ohms is each coil? If you have DVC woofers, are the coils for each woofer wired in series or parallel? Are the speakers wired in series or parallel. Let me know if you need me to clarify anything.
Oct 05, 2007 | Kicker ZX10001 Car Audio Amplifier
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
