Question about Pentax K1000 35mm SLR Camera
On my pentax asaih k1000 when you look through the lense its black- i dont know if the mirror might have fell out or what...
  • 55 Answers
If you look through the view finder and it is black, the mirror is hanged up and the shutter is jammed. The mirror is still there.
Posted on Jun 17, 2010
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
Oct 19, 2014 | Pentax Cameras
I have a Pentax k1000, and was given a few vivitar and olypus lenses. They do not fit the camera. What can I do?????
Vivitar makes lenses with a variety of mounts. Lenses with the Pentax K-mount can be used on the K1000, lenses with other mounts can not.
Olympus lenses will not mount onto a Pentax camera.
You can sell the lenses, give them to someone with the appropriate camera(s), or use them as paperweights.
Nov 21, 2012 | Pentax K1000 35mm SLR Camera
Hi there I just came across my old camera K1000 ASAHI PHENTAX wih multiple Lenses and my Lenses are all Makinon and just wondering if they would work on any other Camera I Have a 500mm F63 Mirror LensI...
Lenses with the Pentax K mount, such as those used by the K1000, will fit onto current Pentax digital cameras, with some restrictions. For more details see
http://support.pentaximaging.com/node/3
Sep 01, 2011 | Rokinon 500mm f63 Mirror Lens for Nikon...
How do I find out the year my Pentax k1000 was made using the serial number? The number is 8410441.
www.pentaxforums.com/forums/pentax-slr-lense-discussion/117545-lense-serial-number-database.html,this is one of the most comprehensive pentax serial number databases around,just click the link i have provided ,once you get there find the k1000 section and find your serial number and that should tell you what year it was made,good luck,if this helps you out please give me 4 thumbs up,it helps my rating,thanks
Feb 10, 2011 | Pentax K1000 35mm SLR Camera
My Pentax KX (analog) wont show apperture in viewfinder. Maybe something block the apperture window. What should i do?
There is a tiny mirror to reflect the f stops to the view finder.
Either this tiny mirror fell off or the needs adjustment.
You have to take out the top cover to have the access to this tiny mirror.
Jun 25, 2010 | Pentax K1000 35mm SLR Camera
On my pentax k1000 the black fuzz looking stuff
That's the mirror bumper, it softens the blow and cuts the noise as the mirror flips up.
Carefully remove it and then replace it with a new one. You can get it as part of a foam light seal repair kit for your camera; this also ensures that the sticky black goo which used to be foam and which prevents light from getting past the edges of the camera back gets replaced. Light seal kits are very cheap, and if you buy a pre-cut version then it makes a fiddly job a bit easier and potentially less messy. They're widely available on sites like ebay, just search for "k1000 light seals" and check that the kit includes a mirror bumper/buffer.
If you don't get it repaired the fuzz will get everywhere and can also get onto the film surface causing white spots on your photos or black spots on negatives/slides. The debris can also get into your lenses so remove it asap. Gooey foam light seals are even worse as it's both corrosive and abrasive (due to the grit it attracts) and gradually migrates to gum up the works. It can also result in light fogging on your photos (usually seen as red streaks from the top or bottom of the picture). Modern foam seals do not decompose like the old ones did.
I hope that I've helped you, please take a moment to rate my answer.
Mar 02, 2010 | Pentax K1000 35mm SLR Camera
Pentex k1000 rewind knob unscrewed, shaft fell inside camera
first make a small hook on the end of a straightened paper clip. insert the hook and pull up rotating the hook as you pull up. being careful not to bend the spring near the hole. once the back door is opened check the rewind shaft, there should be a beveled edge on the collar of the shaft. rotate the shaft while pushing up. if no beveled edge on the shaft use the paper clip to push the spring out of the way while inserting the shaft. if it still will not return file a bevel on the collar of the shaft. I am assuming there is no film in the camera as the canister will prevent the shaft from falling in.
Jan 29, 2010 | Pentax K1000 35mm SLR Camera
Can't get my lense off!
You can use any mm lens you want as long as it was made to fit the K1000.
Is the lens a Pentax lens ?
Push the lens release button down and turn lens Clock-wise then while holding release button down quickly turn lens counter clock-wise, it should come right off.
If it did not then it must be disassembled to remove the lens.
Oct 31, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 camera
VGDHDTH HNTFHDT VGJFT GJ ME MAY
Dec 19, 2007 | Cameras
Will this lense fit on my camera?
You can have the 28-300 temron lens with beynout mount of pentax it will deffinaitly works like another lens manually , because af lens has a option of manual also so it will be suitable
Oct 01, 2006 | Tamron AF28-300mm XR Ultra Zoom for Pentax...
Pentax K1000 35mm SLR Camera Logo
196 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
