Question about Dryers
220 lines i need to know where the wires go on the plug for my dryer.
  • Dryers Master
  • 2,651 Answers
You have a 220v cord you want to installe into your , electric dryer.... easy enough look at your cord .. of the 3 terminal ends either end makes no difference which goes to the terminal block behind dryer. the middle wire needs to hook up to the middle terminal and then the last end goes to empty end terminal, AGAIN END TERMINAL CAN BE SWAPPED, THE MIDDLE MUST BE HOOKED TO MIDDLE, TERMINAL
Posted on Apr 09, 2008
Going from a 3 prong to a 4 prong dryer plug
Admiral AED4475TQ is an electric dryer? Was your old dryer gas? If so, you need a 220 line installed to run the electric dryer. Here is a link to instructions from ehow
Jan 13, 2013 | Admiral AED4475TQ
I am trying to hook up my stackable washer and dryer. I havee a 220 plug 30a what do I need to do so I don't have to go back to home depot and get whole new plug in and plug?
If the unit has a 30 amp/220volt plug, then you will need a dedicated 30 amp outlet from a 220 volt line from the panel. You can not switch the plug to work with a regular (15-20 amp) outlet. Have an electrician install a 10 gauge 220 line from the panel to the unit. good luck!
Aug 30, 2011 | Whirlpool LTE6234D Top Load Stacked...
The following link explains how to properly wire a 220 VAC appliance plug on an electric dryer:
Pay particular attention to whether this is a three-wire or four-wire configuration. There is a difference in how the ground and neutral wires are to be terminated.
If you have any questions, please post back and let me know. I hope this helps you.
Aug 03, 2011 | Whirlpool Dryers
Changing 220 plugs need discription of positive and negitive to dryer
If you are installing a 3 prong cord , then the 2 outer wires , are the power lines , and the center is the neutral . On the dryer , the center wire connects to the white wire on the terminal block . The 2 outer cord wires . 1 connects to the black wire terminal on the block ( outside terminal ) , and the other outside wire , connects to the red ( outside terminal ) on the block . Its the same if you are installing a 4 wire cord , except the green , connects to the ground screw on the dryer itself .
Oct 25, 2009 | Maytag Dryers
I would like (need!!) to create an extention cord for a pool heater (UK) 3000w, 220/240v (13-14 amp). I want to plug it into the 220/240v, 30 amp dryer line. (My only 220/240 line and am unable install...
Use 12/3 gauge rubber or plastic insulation rated for 500 to 600 volts and extend the cable for entire length--don't make a short extension of the existing heater cable. If the total length is over about 4 meters then go with 10/3 cable for safety. The green wire is for the ground pin and the two slanted pins go to 220/240 voltage. Hook the heater end the same as the original cable. That should satisfy any local-disconnect regulations (at least in the states).
Aug 14, 2009 | Kitchen Appliances - Others
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
Wiring 4 wird dryer plug to 3 wire 10/3 for 220 welder
the four wire plug seperates the neutral and ground. the three wire just piggybacks the ground to the neutral. so just get a three wire cord that fits the 220 plug on the generator and install it on your dryer make sure to attach the ground correctly for your three wire setup
May 07, 2008 | Dryers
There should be a diagram inside the back panel
Dec 15, 2007 | Maytag MDE3706 Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
