Question about Sharp CV-P09FX Air Conditioner
Window air conditioner smells like burning plastic, it also has a "sweet" smell...it is brand new and it was running for about 2 hours. It did not have this smell right away. It has been turned off since the odor was noticed. What is likely to be wrong with it?
SOURCE: my window a/c is experiencing a terrible odor mildew smell when I turn it on if I lower the terminstat to 70 it smells worse then if the termastat is 65 I cannot stand this odor I cleaned the filter m
TAKE OUT YTHE A/C CLEAN THEN REINSTALL IT ALSO CLOSE THE FRESH AIR PORT
Posted on May 03, 2009
machtcl1
  • 61 Answers
SOURCE: Burning smell and icing
Sounds like your blower motor in your furnace or air handler has burned up. shut the unit down and replace the motor. make sure the ice is melted and the unit is dry before you turn it back on.
Posted on Jul 20, 2009
SOURCE: Room air conditioner smells like burning
Try cleaning the filter or replacing the filter
Posted on Dec 22, 2009
  • 674 Answers
SOURCE: the air conditioner smells like burning plastic
The fan motor or some other electrical component. Either way I would quit using it until it gets fixed as an A/C unit is cheaper than a house.
Posted on May 03, 2010
  • 50 Answers
SOURCE: brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Posted on Jul 19, 2010
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
Our Kenmore window air conditioner 70051 purchased 6/2/13 makes a burning smell when running.
if new take it back to store and replace it. coud have electrical problems.and cause a fire.
Oct 02, 2013 | Kenmore Heating & Cooling
Burning smell from sym orbit II Burning smell after 10 km * + Add a Comment 1. * By avatarChris mcwilliam 5 hours ago * plastic or rubber - something very mu
Hi, Chris the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Jun 27, 2017 | Motorcycles
1997 blazer,heater bad smell when on
Is it a bad smell or a sweet like maple syrup smell. If its sweet you got a coolant leak probably heater core. Bad smell possible causes burning something up. I would run some water in the in the air intake below your wipers just to see if it changes. Not much but a little. Better or worse in cold tempers. Hwo about when the car first start or has run awhile does the smell get better or worse. More feed back please.
Jan 01, 2012 | 1997 Chevrolet Blazer
Bad smell in cellulose pad
These all smell when new.
Run the unit on high for a few hours and the smell will eventually go... New celdeks smell like wet nappies when fiorst used.... dont panic its normal.
Jun 16, 2011 | Mastercool 67471 Evaporative Cooler Air...
Water collecting on driver's side floor of my 2002 mitsubishi gallant
If your car is using / loosing water.... or the air smell sweet in the car vents then heater core is leaking. If your not loosing water from the radiator and doee not smell like that sweet anti-freeze smell then your airconditioner evaporator drain is clogged. You can attempt to clear the evaporator drain by locating the drain outlet and shoving a small soild stranded wire up through the drain vent. Make sure you have the blower motor and the air-conditioner on when trying to clear the evaporator drain. Be careful NOT to shove the solid strand wire into the evaporator coil while trying to clear the drain. The only other option is to remove the AC system evaporator lower cover and clear the drain which takes hours and hours of work.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | Heating & Cooling
Window ac has sweet smell
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 28, 2010 | Frigidaire FAC125P1A Window Air...
Brand new portable air con- burn smell
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
Window air conditioner repair
when you smell something like that it only means your unit is leaking.the freon/refrigerant is what you smell.so i suggest compare a brand new one with the labor cost for repairs in your area.
May 18, 2009 | Heating & Cooling
Plastic smell
Be sure all packing materials are removed your operators manual will tell you how to remove them.
Jun 09, 2008 | GE AJCQ08ACB Air Conditioner
Sharp CV-P09FX Air Conditioner Logo
710 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
