Need new remote for TV - Televison & Video
  • 8,617 Answers
Www.replacementremotes.com should have the remote you need, just enter the model number of your set into thier search box
Posted on Apr 08, 2008
SOURCE:
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
My TV does not respond to the remote. I can only turn the tv on and regulate the sound by pushing the bottons on the TV
IS it a universal remote? If yes, remove the battery, wait for 10 seconds or more, fix the battery back in and re-register the remote with the TV by entering the code. But it the remote works with the TV without code, try again. If this doesn't fix the problem, please read further.
Try the remote with new batteries, ff new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
I hope the above makes sense to you.....
Good luck.
Apr 04, 2011 | Televison & Video
IR Remote Control Remote Control: how do I set up my remote with a brand new insigni...
If you have a universal remote control, programming details are included in the remote manual. If you need to program the Insignia TV remote, details are also in the TV owner's manual. If you need a copy of the manual for your TV, a downloadable version can be found at InsigniaProducts.com by searching for your TV model number and clicking Support.
May 17, 2010 | DISH Network IR Remote Control
I NEED THE CODES
each remote has a new setup.normarlly oo4 does it.
Mar 02, 2009 | Universal Remote Control 10694 Remote...
New settings on tv remotes
Hello Slffvo:
Here are a few web sites that may help you out.
http://www.hifi-remote.com/ofa/devices-tv.shtml
http://www.universal-remote.net/philipsmagnavox.html
Aug 14, 2008 | Philips Magnavox Learning Universal Remote
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Televison & Video Logo
Top Televison & Video Experts
Ekse
