Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler 17.5 command. will not start
I have a Kohler 17.5 command. getting fuel and spark. took air filter off. still wont start. just backfires through carb as im trying to start it. any ideas?
  • 905 Answers
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
Posted on Jun 12, 2010
What to do? I have a craftsman GT 5000 with a 25 HP Kohler and it will run for about 10 minutes and then start cutting out and die. I have changed the fuel filter with no resolve. What should I look at...
Make sure the choke is coming off. Check the compression.Many times the head gasket may leak when the engine heats up. Also check for spark sometimes the magneto can heat up and quit after running a while. See if it will run if you prime with a little fuel, if so ,some of the Kohler engines this size have a fuel pump that could be failing. Check for vapor lock. It takes air and fuel properly mixed, spark and compression any of these missing the engine dies.
Aug 06, 2014 | Kohler Command Pro OHV Horizontal Engine...
I have a kohler 18 hp twin engine on a cub cadet. Backfire when shut off. Started back up sputtered. Fuel coming out by air filter. Took air filter off and ran great. What would be the problem?
Check to make sure idol isnt set too high, make sure the air filter is infact clean to prevent it from chocking itself, make sure choke is off :-) and also make sure you idol all the way down when you kill it. Make sure your spark plug is good to prevent flood, and detonation, peaceout.
May 05, 2014 | Garden
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kohler k321as engine- misfiring.
sometimes there is a adjustment screw that you can turn just like a car.CAREFUL NOT TO TURN TO MUCH.to burn lean or rich.also you might want to change the fuel and air filter's first,then try to adjust.
May 25, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler motor starts then carb loads up with gas
If the engine is running rough then this could mean that you have weak spark or valve adjustment. When an engine runs rough it will not burn all the fuel, which will create excess fuel in the air cleaner housing. Also, make sure the the float is closing in the carberator.
May 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
1,608 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
