Question about Garden
Does anyone know how to patch spalling soft red brick? My 1930's building is falling apart and I can't find anything that will hold. Thanks... The mortar is fine, it ts the face of the old red brick that is popping off.
    Top Expert:
  • Garden Master
  • 76,649 Answers
To repair a soft or hard red brick you cut out the affected part of the brick with a toothed chisel or diamond cutting disc. You then rake out or cut back the pointing around the brick to well below the surface. Grind up the red brick rubble to a very fine consistency and add the dust from a matching ground up red brick with a little white sand to give you the texture of the brick then add white cement with dark red colouring to match the colour tone of the brick face adjacent.
If you want a perfect match you need to allow the mixture to dry on a mortar board overnight to see if the colour is going to be right when dry. If the mixture is correct, you can then mix up a large batch to fill in the cut out or imperfections.
The brick cavity needs to be well watered to make it damp, then you fill in the hole with a semi wet mixture of the brick repair material and allow the mortar mix to soak into to the host brick. Once the surface of the repair material becomes less shiny,which means that the mix is soaking into the host brick, you can then use a piece of timber or small wood float to shape and make the surface of the repair blend in with the adjacent bricks. Do not use metal trowels to form or surface the repair because this brings water to surface and makes the material too shiny or smooth. After forming the repair to the correct shape you then need to cut around the repair material with a straight edge and a pointing trowel to form a false chase for the pointing to match up with the existing pointed courses. As the material is drying you can also carefully rub in some more ground up brick dust to blend in the colour. When you are on the final finishing of the red brick repair you must use a soft paint brush to keep all of the surfaces matt and give the repair a blended appearance. Once the repair is dry you can carefully clean out the pointing around the brick and point up as normal. You can short cut this procedure by using red brick dust on a sand and cement repair but in time the ground/base material will show through, by using a red coloured ground/base material the repair will last as long as the brick itself. One note of caution is that red bricks are normally very brittle and if repairs are made to the brick they might break or spall on the other side of the repair if a heavy frost happens soon after the repair is made, bricks have been repaired in this way in the UK for many years. Please try not to use chemical additives because they make the repair material too hard and more likely to hairline cracking over the long term.
Red Pigment can be also used to touch up the repair but in time this will wash off, so alway try and use fine ground red brick rather than colouring.
Posted on May 31, 2010
  • 8,197 Answers
Why won't my Fridge/freezer, freeze ice cream? But freezes popsicles and meat, model number MTB2195AE* Im GUESSING its the defrost control that needs to be replaced? NO ICE build up.
Your have a good idea re the defrost timer. But there is also a thermostat that turns the compressor back on when the temp hits a certain point during the defrost cycle and defeat the normal cycle.. Check that out.
Mar 24, 2017 | Refrigerators
I have a 2 story brick home. The bedrooms are extremel hot in the summer even though I just replaced my air cond system.. Is it possible to put that expanding foam insulation in the outside walls without...
i doubt building regs will allow that (if you're in the UK), but drilling holes through the cement between bricks every few layers and every couple of bricks apart, then pumping the cavity with polyurethane foam........ and you'll need ALOT of PU foam!!!
you should really try asking in the right place first though, not here (problem with Nikon Coolpix Camera)?????
Jun 16, 2014 | Nikon Coolpix S9100 12.1mp Digital Camera...
I have been given a Technics system with tuner (st ch7l), cd (sl ch7), amp (su ch7) & tape deck (rs ch7) with 2 Bi wire speakers! But I have no ribbons or speaker connections! Can anyone tell me where...
What AJIN GOPAKUMAR says.
You can buy cables and speaker wire at Best Buy, Wal-Mart, Parts Express or Amazon. Even a "dollar store".
One thing to keep in mind - do not fall the hype of people who want to sell you very expensive cables because they will sound "better". $2-8 for a set of RCAs should do nicely.
You don't need Monster Cables or their even more expensive brothers. There are many cables that fit your needs. One example on Amazon is "Hosa Cable CRA202 Dual RCA To Dual RCA Cable - 6.5 Foot". Another is Parts Express's "RCA Patch Cable 6 ft. Gold Plated" for $1.80 plus shipping.
More expensive cables will not hurt anything. But they won't help anything in your set-up.
And keep them short, if you can, for neatness ... though long ones won't hurt anything.
Before you buy speaker cable do some measuring ... and add several feet. You will be just fine with lamp cord or zip cord from a hardware store. "Speaker cable" is the same thing with clear plastic covering, often color-coded. This can be helpful because the most important thing to know about wiring speakers is that the MUST be in-phase -- red to red and white-to-white, or plus-to-plus and minus-to-minus. THIS IS VERY IMPORTANT! Check and double check!.
Oct 24, 2012 | Audio Players & Recorders
The walking foot falls apart. The screws slowly work loose and it falls apart
Get some thread locking compound such as Loc-Tite Blue at a hardware, building supply or auto parts store. Paint a stripe of the stuff all around the screw threads over about 1/4" of the length of the screw away from the head. Let it set up according to directions. The screws should hold properly for several assembly/disassembly cycles. Re-apply as needed.
If the screw threads are too worn and sloppy to hold even with this, then you may need to replace the parts.
Jan 17, 2011 | Brother XR-65t Mechanical Sewing Machine
Front wheel wont stay on
Hi
visit www.buggypitstop.co.uk/ they give excellent advice and would be able to fix that for you at a reasonble price.
thanks
May 05, 2010 | Britax Verve - Red Umbrella Stroller
Problem burning Bomberman Land
I know you might think I sound crazy, but do not patch the ISO, and burn it exactly as you dled it, if you burn and it asks for an update, accept it, make sure your wii settings are the way you like in case of bricking, once update has taken, you should reset and see if it works from there, I noticed when making my backups, that patching the game is actually worse than burning it as is, as long as you are content with your Wii internet settings you should be fearless to brick because future games will have updates from your region which will unbrick your console, just something to think about.
Jul 15, 2008 | Ubi Soft Entertainment Buck Bumble for...
Brick connection is not registering
It sounds like that brick fell. All bets are off when a hard drive falls or receives shock. Put your ear to it and see if it is making any strange sounds.
Keep me posted.
Nov 21, 2006 | LaCie BRICK (301063U) 300 GB Hard Drive
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
