You haven't specified here about have did a lamp time reset after lamp replacement. It should be done. If you wish to know more about how to reset lamp time, http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there. You can get details. Do this, and check it again. If you want any more assistance, be free by commends.
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Hi, what you need to do is reset the lamp hours to get the red light to go if it is a new lamp. To do that plug in a source such as a laptop or dvd player. When the display from the laptop or picture comes up go into the menu and reset the lamp hours I had the same problem. Hope this works if not let me know.
When was the last time the tv projection lamp was change in this tv?The projection lamp in the tv now,if 1 1/2 or 2 years olds,tv on an in uesd like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.Hear alot of clicking too?The board call the Ballast board also require changing.This Ballast board help to ingnite the projection lamp.
It could be the lamp, they have an approximate 1 year life depending on conditions. If you bought the TV new, it has a 1 year warranty and labor you might want to contact warranty support. They will send you a new lamp.
To Receive a Replacement Lamp Under Warranty Call (800) 553-7278. Please have model number, serial number, and TV purchase date available. Important: All lamps replaced under warranty must be returned to Mitsubishi where they will be inspected for defect verification.
Appendix C of the manual describes how to change the lamp. Handle with care (avoid fingerprints on the new lamp). Make sure the TV is off for at least an hour before starting.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Check that when you turn on the TV the Lamp is striking (turning on).
My thoughts are that you will have to reset the lamp hours counter to make it work, as the TV does not know that you have replaced the lamp. To do this, check the leaflet that comes with the lamp - it should explain how to reset the counter for the lamp hours.
No do not reset the lamp hrs. because the lamp might reach the ed of life and could blow resulting in mercury poisoning. If you notice there is a warning sign that pops up in red or something saying to change the lamp, it will shut down eventually during that warning time. You have gotten a lot of hours with that lamp and consider being fortunate to have such reliability. Buy a new lamp when needed as it will improve your experience.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
