Question about Dometic Refrigerators
DOMETIC REFRIGERATOR 2607 NOT COOLING. AC & GAS INDICATORS OK.
  • 4,924 Answers
If it runs the compressor and all ...(hear teh motor running ) but the yemperature do not drop to the normal level ...than you should take a look and see how the temperature is set ..it should be to about 27 F to actually freeze a little ..cause on 32 is the freezing point .If temperature is set ok ..but still not freezing than it needs to be taken to a repair shop and see for freon leaks...the only possibility to start the compressor ..and work ..but not freeze ..is the lack of freon ..(also check the fan t see if its spinning )
Posted on May 31, 2010
Dometic RM2611, Freezes fine, Refrig OK on AC, but warms up when on LP gas. Can I safely increase the orifice size from #53 to #58? Thinking that will increase the flame and produce more heat.
Check the gas regulator and the lines for particles of dirt. You have modified the refrigerator it is going to take some work to find what is wrong. Don't modify the orifice from what it calls for.
APPLIANCE 911
Aug 27, 2016 | Dometic Refrigerators
Rm2352 will not work on AC, pilot will light, but then will go out. No cooling
LP check for cobwebs in lines and good gas pressure ac check heater element if ok disconnect thermistor from back board run overnite if ok replace thermistor if not bad cooling unit replace
Jan 29, 2014 | Dometic RM2652 Refrigerator
Dometic 2652 cooling on gas but not on a/c
No AC operation
- operates on gas mode
Operation
AC Volts
Fuse
Heating Element
Wiring
Lower Circuit Board
Jul 03, 2011 | Dometic RM2652 Refrigerator
Dometic rm 2607 makes a gurgling sound when started in a/c or lpg . no cooling, in fact the inside of fridge heats up.help ? thanks
If your cooling unit is gurgling, then you have air in the system or a bad cooling unit. There is a process known as "burping" that should help repair this. It is a rather lengthy process and will require two people.
1. Access the rear of the refrigerator. Turn off the LP gas to the unit. Remove the LP Gas line and the 12Volt supply. Unplug the fridge.
2. Remove the screws in the rear at the bottom and then remove the screws from the inside.
3. Pull the fridge out and lay it down on it's right side for 8 hours.
4. Flip the fridge on it's top for 8 hours
5. Now the left side, then back to normal.
6. Reinstall the fridge and turn gas back on.
Hope this helps,
Jeff
Jul 08, 2009 | Dometic CS-200 Wine Cooler
Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Jul 06, 2009 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
