Question about Pioneer AVIC-S2 GPS Receiver
Becker 7914 freezes
I have a Becker 7914 Traffic Assist GPS unit that freezes on the Becker logo screen before it gets to the main menu. The unit also isn't recognised when connected to a PC. I've read that for many Becker units you can solve this problem by re-installing the software to the flash memory via the SD card which is one method recommended by Becker on their website for updating the unit. However for the 7914 there are no update files available on the website, although at least most of the original software files are on the CD supplied with the unit. Can you advise how I can re-install the software from the SD card? The critical point is what file does the Becker run from the SD card (many units seem to run an autorun.exe file) and where can I obtain this file? Also what directories should the file be in on the SD card.
If the problem can't be solved this way, can I solve it using a JTAG cable? I've located six pins close to the CPU (test points 1,2,3,5,6 and 7) which look promising, but are you able to advise which connection is which (TDI, TDO,TCK etc).
Many thanks
  • 8 more comments
  • florinc Apr 26, 2008
    Hello transition, I have the same unit and the same problem. Have you found a solution ? Please email me at florin.cremenescu@gmail.com
    Many thanks.
  • wolf whatley May 05, 2008
    the gps will turn on but wont do eny thing else if you know whats wrong emil drdoomt3@aol.com
  • Anonymous Jun 03, 2008
    I have the same problem. It freezes. How can I reinstal the softver?
  • ghosty69 Jul 16, 2008
    manoside@freemail.gr
  • sas7 Aug 03, 2008
    I have the same problem with my 7914. PLS HELP
  • rudi875 Oct 12, 2008
    the same problem here
  • drsulee Dec 21, 2008
    i have the samw problem with 7929 plz help? the logo page comes and not a single button works, initially I started it and started to work but i didnt charge it for 2 hour i think and then it got stuck.. still the same do know an answer? plz email drsulee@gmail.com .
  • gasaviation Feb 14, 2009
    Same problem !!!! help please
  • Anonymous Mar 21, 2009
    please can someone tell the solution
  • infos274 Apr 01, 2009
    Same problem with BE7914
    tout-ici.fr
SOURCE: Connections for Pioneer CDX P610 Changer
The small black wire needs to be earthed.
Posted on Oct 06, 2007
Eagleeyes
  • 199 Answers
SOURCE: AVH-P5700DVD & AVIC-800DVD
hi sounds like its not reading your disc correctly
check you disc to be sure its clean and scratch free
you could also try useing a cd cleaner disc.
other wise a full service or laser replacement
Regards
Mark
www.Blueice-electronics.co.uk
Posted on Feb 24, 2008
  • 3 Answers
SOURCE: my DEH-P690UB doesn't read my ipod
I spoke with my friend at local car audio shop, apparently even though they don't say so pre-5g ipods are not supported without the ipod adapter box. I think I paid like $30 bucks for it and now my mini works fine with the deck.
Posted on Mar 07, 2008
  • 8 Answers
SOURCE: GPS PIONEER AVIC-S1 UPDATE
Please check the update procedure as below. It's very easy.
http://www.pioneerelectronics.com/PUSA/Support/Navigation/AVIC-S1+Firmware+Update
Posted on Jun 20, 2008
MrLard
  • 94 Answers
SOURCE: RCA Inputs for Pioneer AVM P100
An I-Pod connection box connects to the RCA inputs and the IP-BUS connection.
Here is a picture from the AVM P7000R manual showing the connections the IP-BUS lead is marked by the red square.
The cable looks like this -->
and you can buy it here ->LINK<-
Posted on Jun 26, 2008
Zh&k z101 i forget my phone code
I BUY ZH&K PHONE MODEL Z101 MY QUESTION IS HOW TO OFF THE "FLIGHT MODE", BECAUSE I CANNOT MAKE A CALL & INCOMING OUTGOING TEXT..
Feb 19, 2014 | DURAGADGET Screen protector for Becker...
Becker 7914 hold in logo
softwear fault you need to up plug the battery indide and leave out for awile.
Dec 29, 2013 | Nextar Q3 GPS Receiver
Battery becker 7827
Assuming you have or are able to extract the old battery, find the model number of the battery and google it. Odds are you'll get multiple replacement options.
Apr 28, 2013 | Becker Traffic Assist 7827 Personal...
Garmin is stuck on loading maps and doesn't go beyond this point
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
  • The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
  • Market Name: On the Road
  • Serial Number (listed on the bottom of the device)
  • Question Type: Repair Information
  • Provide a short description of your problem or question: nuvi frozen on Garmin Logo
  • Full Name
  • Contact Phone Number
  • Shipping Address
Nov 12, 2010 | Garmin nuvi 205 GPS Receiver
Screen is stuck on loading maps screen, garmin nuvi 1200
  • Full Name
  • Shipping Address
Nov 11, 2010 | Garmin nuvi 1200 Car GPS Receiver
The garmin was droped , screen is white with some marks on the inside?
  • Full Name
  • Shipping Address
Nov 11, 2010 | Garmin nuvi 1490T GPS Receiver
Want to update my becker gps
Did you ever get an answer to this problem? I'm having the same problem
Jul 29, 2010 | Becker Traffic Assist 7914 Car GPS...
I nead a instruction manual for becker traffic assist
Go to http://www.mybecker.com/. Click on the Mobile Navigation link and select your model number. On the specific model # page, there is a Downloads link that gives you the option to download an 'operations guide.'
Hope this helps!
May 16, 2010 | Becker Traffic Assist 7827 Personal...
Pioneer AVIC-S2 GPS Receiver Logo
836 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
