Question about Dell 926 All-In-One InkJet Printer
Printer won't print; pending documents stay in queue.
  • 54 Answers
Possibly, the printer driver is corrupt or wrong version, printer cable is bad or not plugged, printer on standby (not online), or defective printer.
Do a self-test print on your printer. Most printer has self-test print function, look into your model's documentation. If the self-test prints, then more likely your driver issue. Uninstall the printer driver and reinstalling should resolve it. Goto Start->Control Panel->Printers. You can remove and install printers from there.
Posted on May 30, 2010
Stevenslav
  • 65 Answers
SOURCE: documents keep pending and not printing
You need to either unpause the printer manager or delete all the queue's and restart he computer. Since you have not provided information on the operating system you use, I can not help you further.
Posted on Jun 05, 2009
tom19511
  • 1601 Answers
SOURCE: Printing problem
Blinking lights:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859572&lc=en&cc=us&dlc=en&product=1100995&rule=44647&lang=en
Offline:
  1. Open the Printers folder.
  2. Right-click the icon of the printer in use, and then click Open .
  3. Click Printer on the menu, and then ensure that there are no checkmarks next to Pause Printing or Use Printer Offline . If a checkmark is present on either, click the menu option to remove it. If the menu shows Use Printer Online , click that option.
  4. If neither Pause Printing nor Use Printer Offline are checked, press Esc to leave the menu without making changes.
Posted on Nov 30, 2007
  • 72 Answers
SOURCE: pending printing
Printers and faxes then highlight printer then go to file and select set default printer. Then open printers and faxes go to file select restart
Posted on Apr 15, 2009
md_ehsan_1
  • 255 Answers
SOURCE: Printer installed correctly however will not print.
1. uninstall your printer
2. restart your system
3. re install your printer
4. after installation take a test print
5. hope this will correct your problem..
6. otherwise, run Advance system care to fix your computer problems, such as registry errors etc., due to some registry problem are some other problem in your software makes like this problems.. download from the following link..its a freeware software..download it and install it, Press CARE to start the program.
Advance system care (registry cleaner)
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
Posted on Jun 22, 2009
SOURCE: document pending will not print
my printer won't print a pending document, how do I print it?
Posted on May 04, 2010
Every time I try to print to my Dell 3110cn printer, a message pops up stating "Load Tray 1 024965 Executive" Paper tray is full and inserted correctly...what do I need to do to make it print?
I would try two steps:
1) Check the "pending documents" for your printer and make sure the printer queue is empty - delete any pending document.
2) Check the printer settings and make sure the default paper type is not set to "Executive". You may also check this in the paper properties of the document that you want to print.
Apr 29, 2014 | Dell 3110cn Laser Printer
Not able to print, keep saying 1 document on pending. I have deleted everything and still no able to print. scanner, copier and fax is working normally.
Your document is stuck in the printer queue. Usually you can fix this by shutting down the printer completely and disconnecting the power connection then starting over. Depending upon your computer and the software you are using it may be possible to have the computer empty the queue
Aug 22, 2013 | Brother MFC-7860DW Duplex Wireless Laser...
Will not print all conections are good every thing sits ,but does not print have 9 documents pending
Hi. You will need to clear the queue first as it will just accumulate in it if the pending documents remain. There are articles in the Lexmark website to help you remedy the problem. Just click on the links. This first link: http://bit.ly/agrrFg will help you remove or cancel print jobs in Microsoft windows. If the print jobs are still stuck in the queue, click on this link: http://bit.ly/aVuCwm and follow the instructions carefully. Once the queue is cleared, unplug the printer usb connection from the computer and plug it back in after 5 seconds. Try printing again. Good luck!
Mar 24, 2010 | Lexmark X4270 All-In-One InkJet Printer
I am trying to print and the computer is saying my documents are pending in the queue how do I print!?
Thants means some pending peinted or pronting documents in que in printer,Please follw the given instructins,,
choose start button
go to setting --> printer and fex option
you see the connected printer,
choose the printer and Right click of the mouse on that icon.
choose open option
you see many pending documents in screen,select all documents and right click of the mouse -->cancel -->Ok
Queue is nil
than you will ready to print.
Thanks
Dec 19, 2009 | Office Equipment & Supplies
Document failed to print" message
Hi go into settings on you're printer & clear the pending queue it will not print till u delete them ..cheers
Jan 18, 2018 | Dell 1600n All-In-One Laser Printer
Documents keep pending and not printing
Jun 05, 2009 | HP DeskJet F380 All-In-One Printer
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
How do I get the printer to print
Click on the printer icon at the bottom right of the screen. It should bring you to the print queue.
Make sure that the print queue has been released. Sometimes the queue will be in a "Hold" status.
You can also release each print job by clicking on the job and directing the queue to send the job to the printer.
Don
May 20, 2009 | Lexmark X6100 Flatbed Scanner
Pending printing
Apr 15, 2009 | Office Equipment & Supplies
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Dell 926 All-In-One InkJet Printer Logo
2,343 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
