Question about Leviton #601-6696-I Ivory Wireless 3WY Switch
Leviton wireless switch for outdoor lights no longer working
A Leviton switch (the back of the switch reads "Cat No 16400, DHC Wall Controller") controls the outdoor lights over the garage. We've lived in the house for 7 years and it stopped working reliably about 3 months ago, ie, the switch would have to be turned on then off then on multiple times to active the outdoor lights, in spite of the fact that a red LED on the front of the switch reliably turns on and off. Now the switch appears to have stopped communicating with the outdoor lights, although the LED still goes on and off. The outdoor lights are stuck turned on. I've opened the junction boxes for the lights in the garage and cannot identify any kind of receiver. Nor can I find any info about how the receiver for the indoor switch is installed. I would love to fix the lights, and it seems like replacing the switch and receiver would do the trick, but I'm at a loss for information. Thanks in advance for your help!
gotgeek2
  • 565 Answers
SOURCE: leviton wireless switch fails to work all the time
50 feet is the maximum range for the switch, per manufacturers spec. Range is diminished somewhat for walls, doors, etc.
IIRC, there is a plug in transceiver available from Leviton, however, if the price of the booster for the main panel is included in the $100 installation, then I'd say that's a fair price. You may try to keep fresh batteries in the switch.
Posted on Jan 25, 2009
  • 323 Answers
SOURCE: 6696 Decora Anywhere Switches triggered by other signals
These switches have an RF operating range of about 50', according to the manufacturer's spec. It is unlikely the neighbors are tripping them. Look around your neighborhood for a ham or CB antenna. That could do it.
Also, these switches run through the AAA batteries pretty fast. You might check them.
50' is not much range for an RF signal. You may take a look at Insteon, which have about a 200' range. Also, they create a "dual mesh" signal by mixing RF with the electrical current in the lines in your house.
Posted on May 29, 2009
buffalonyman
  • 1865 Answers
SOURCE: wiring a leviton 5625-W switch receptacle combination
You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
Posted on Sep 02, 2009
gotgeek2
  • 565 Answers
SOURCE: I have two Leviton Decora Motion Activated Light
Unfortunately you cannot use two PR180-1LA's for what you want to do. :-( There is only one correct installation:
One PR180-1LA needs to be installed at the switch box which contains the cable that goes to the light (load). That is a must. One then installs a regular 3-way switch at the switch box which contains the cable with the hot from the breaker (line or source).
If you reverse the sensor location you will need 4 wires between the switches, which is not usual practice, as the bare grounding wire is not permitted to carry current per National Electric Code rules.
If you want a sensor at both locations you need to install a IPP15-1L at the switch box that has the cable going to the light (load). One must then install a IPP0R-1L at the switch box that has the cable with hot from the breaker (line or source).
Posted on Feb 19, 2010
CaptAdams35
  • 28 Answers
SOURCE: triple rocker switch to control 3 function bathroom fan/light
I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
Posted on Mar 09, 2010
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
Is there any products that replace leviton DHC 6225 remote switches this is a old part number.If not is there another part number I can use for replacement
I believe the switch is the same as an X10 switch (WS467). I have interchanged the two in the past. They are also available on ebay.
Nov 04, 2014 | Leviton Electrical Supplies
Lights turning on
Try changing the code in both switches to the next available number. Some one nearby may have set their lights to work off the same code and thus activating yours as well. As to replacements, just google cat# 6319-2. lots of options.
Jan 23, 2014 | Leviton Electrical Supplies
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or...
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
Sep 11, 2011 | Electrical Supplies
I have installed a 2-way dimmer switch in my dining room. I was able to install it and it works great. However, on the other side of the wall where I installed the switch, I have another single way...
If I understand correctly new dimmer is in different box than outdoor switch.
And outdoor switch controls different light than new dimmer.
Both new dimmer and outdoor light are on same circuit breaker, and that breaker is not tripped.
Outdoor problem could be related if loose wire inside dimmer box also feeds over to outdoor switch. More below.
Here's how I would troubleshoot problem.
1) Check outdoor bulb(s). This step can be big time saver.
2) Pull outdoor switch out of box a bit so you can see and test wires.
3) If wires are pushed into quick connects located on back of switch, these connects get loose. Moving switch usually causes loose wire to connect again, so turn switch ON-OFF and see if outdoor lights work. Sometimes switch works fine after quick connects reconnect. If quick connects are bad, use tiny screwdriver in slot next to connect-hole to release wire. And then connect wire to screw terminals on switch. Or replace switch.
4) Turn switch to OFF, use tester and test both screws on switch to bare ground wire. Tester should light up on one screw. If tester does not light up, then switch is not getting power, and that wire has to be tracked back to see where short is.
a) Look if one of the black switch wires is connected to other switch, or connected to other black wires inside same box. This wire might have come loose.
b) Look at white wire inside same box and make sure they are twisted together and covered with wire nut.
c) Now here is where dimmer could be related ... if white wires are joined together in dimmer box, they could have come loose if they were not properly twisted together and covered with wire nut.
http://waterheatertimer.org/How-to-twist-electric-wire.html
5) Turn switch to ON and test again. Tester should light up on both screws. If switch does not light up on both screws, then switch is bad. Replace switch.
Add a comment if you need more help.
Dec 01, 2010 | Leviton Decora Light Dimmer Switch
How does levition 6696 switch work?
The Leviton 6696 Anywhere RF(Radio Frequency) lighting control allows you to add an additional (wireless) switch to an existing switched light(s) without having to hard wire it. For example, let's say that you have a bedroom with a switched overhead light. The Leviton 6696 RF receiver would be installed in place of the existing light switch. It will still function and is wired the same as an ordinary switch. The Leviton 6696 Anywhere RF transmitter (after installing the batteries) can then be used anywhere within 50 feet of the receiver (that replaced the existing light switch) to also control the light. You don't have to mount the transmitter if you don't want too. It can be on the night stand, (or carry it with you if you want) so you can turn the light ON and OFF from the bed or wherever.
Oct 21, 2010 | Leviton #601-6696-I Ivory Wireless 3WY...
Wiring diagram for Grounding switch with a pilot light. Cat # 1221-PLC
http://www.leviton.com/OA_HTML/ibcGetAttachment.jsp?cItemId=y8QWKImQP7cPVn3GRND9ig&label=IBE&appName=IBE
Jul 18, 2009 | Leviton Electrical Supplies
Leviton wireless switch fails to work all the time
Jan 15, 2009 | Leviton #601-6696-I Ivory Wireless 3WY...
Leviton #601-6696-I Ivory Wireless 3WY Switch Logo
272 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
