Question about Peg Perego John Deere Gator HPX Ride on Toy
Right wheel wont go around but left wheel will
    An expert whose answer gotĀ voted for 100 times.
    Habit-Forming:
  • 156 Answers
It might be a motor or switch problem. I had this problem and found some repair help at http://www.mypegperegoparts.com/
They seem to know a lot about these.
hope this helps
Posted on Jun 08, 2010
My ignition switch wont turn nor will my steering wheel
use a different key,or pull on the wheel while turning
Jul 30, 2015 | 2004 Cadillac Deville
How do I change a grinding wheel to a Wire wheel on my new grinder # 37823
There is a left handed thread and a right handed thread on the arbors.
Removal
Right Hand Side (RH)
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CCW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CW.
Installation
Note: Hand tighten the nut, then 1/4 turn.
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CWW.
For grinding stones:
  • ring test the stone
  • discard the stone if it has been dropped
  • be sure the paper washers are installed on the wheel
GRINDER SAFETY 101 (graphic injury video so be warned)
http://www.garagejournal.com/forum/showthread.php?t=263083
Feb 14, 2015 | Grinders
Have tried everything, can't get one of the grinding wheels off.
On a bench grinder the wheels turn towards you. This means the grinding wheel on the right side, has a right and nut, and the left side has a left handed nut. If you're trying to remove the left side turn the nut counter-clockwise
Aug 16, 2010 | Delta Grinders
Check abs system lite on how do you find the code list
ABS Fault Code List 1991 Corvette (C4)
Code Definition
21 Right Front Wheel Speed Sensor Fault
22 Right Front Toothed Wheel Frequency Error
25 Left Front Wheel Speed Sensor Fault
26 Left Front Toothed Wheel Frequency Error
31 Right Rear Wheel Speed Sensor Fault
32 Right Rear Toothed Wheel Frequency Error
35 Left Rear Wheel Speed Sensor Fault
36 Left Rear Toothed Wheel Frequency Error
41 Right Front Solenoid Valve Fault
45 Left Front Solenoid Valve Fault
55 Rear Wheels Solenoid Valve Fault
61 Pump Motor or Motor Relay Fault
63 Solenoid Valve Relay Fault
71 Electronic Brake Control Module Fault
72 Serial Data Line Fault
75 Lateral Accelerometer Fault (Short ot Open)
76 Lateral Accelerometer Fault (Signal out of Range)
Mar 12, 2010 | 1991 Chevrolet Corvette
How do i setup the g25 to my ps3
i have a g25 wheel on my ps3 it is simply plug and play.
if you struggle with buttons check this out it has all the functions:
Buttons for the G25 wheel and PS3
Top 4 The Black ones
Top-triangle-cancel-reverse(gear to back car up)
Left-square-cancel
Right-circle-E_brake
Bottom-X-enter You can also use the gas pedal for enter
Bottom 4 buttons The Red ones
Far left-no function
Second button-Change view
Third button-Pause-quick exit replay at the end of race-This button will also speed up the winnings (to keep from waiting with the cup spinning around so you can get back to racing)
Fourth button-best race line for license test
Buttons on wheel
Left-look back (default)
Right-nitro (default)
I change these two buttons around myself so I have the nitro on the left.
D-pad-same as the controller up,down,left,right. For menue use.
Also for (during race)
Look back-bottom pad
Look left-left pad
Look right-right pad
To change any of the button functions use the DFP settings in the options menue.
I have not used the wheel in photo mode. The only thing you can't do with the wheel is "exit" game. I also never have my controller on during gameplay I only turn it on to exit the game. If anyone needs anymore help with this wheel give me a shout-back and I'll try my best to help.
One last thing make sure your wheel is in the far left port(port 1) or port 3
Oct 08, 2009 | Logitech G25 Wheel And Pedals Set
Wheel turnd left OK Wont turn right, Get loud
THE GEAR ON THE SHAFT IS STRIPED OUT NEEDS A NEW ONE
Sep 05, 2009 | Garden
Front drive noise when turning left/right
the C V JOINTS have hadit.that is the constant velocity jointsare badly worn and need replacing youdoit
Jul 27, 2009 | Hyundai Excel Cars & Trucks
One wheel wont turn
Turn, I assume you mean turn right and left?
Yes, that arm is likely the tie rod. There is no pin that can be replaced, the unit needs to be replaced.
If it is the outside tie rod end, you have an easy job ahead of you. Cost about $30 or so. You'll need a front end alignment.
If it is an inside rod end, you should replace your rack. Cost around $100. You'll need a front end alignment.
Have fun!
--Mark
http://www.marksatterfield.com
Mar 12, 2009 | Lincoln Mark V Cars & Trucks
Peg Perego John Deere Gator HPX Ride on Toy Logo
99 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
