Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
How do I get the lower discharge pipe reconnected to the non return valve body and then the discharge elbow without it leaking?
  • 349 Answers
Http://www.saniflo.com/pdf/install/PLUS_US.pdf
This is a link with a installation guide I hope it will be helpful to you.
Posted on Jun 11, 2010
My saniplus leaks/sprays watse from the discharge elbow at the base of the unit, it is popping up and leaking during discharge
no,you need to take it apart and replace the gaskets,they are under pressure and glue will never hold,read about it here, Saniflo Extension Pipe
Sep 16, 2014 | Saniflo SaniPack SaniPack Concealed...
Water leak inside of unit around pump head
1. Disconnect electrical supply.
2. Remove top cover.
3. Remove pipe from elbow on top of pump body by unscrewing knurled collar.
4. Then, unscrew elbow from pump body.
5. Wrap threads of elbow with a few layers of plumbers PTFE tape.
6. Then carefully screw elbow back in to pump body (this can be a little tricky - be gentle and take your time - this worked fine on my Gaggia Classic).
7. Then re-attach pipe with collar. NOTE: The top of the pump body can be rotated by gently twisting - to get the pipe at the correct angle to the boiler and allow the pump to sit vertically on its bracket.
8. That's it! Check your machine is dry and clean, re-assemble, plug it in, prime the pump (it's in the manual) and pull a shot!
Jan 25, 2014 | Gaggia Classic Espresso Machine
Saniplus toilet when toilet is flush the masorator tank leaks around the lid, nnot nice seeing \yuck streaks run down
Is not recommended to use 90 degree elbows in the discharge pipe. Is recommended to use 45 degree elbows back to back with a small piece in between or long sweeping elbows. Using hard 90 degree elbows creates resistance in the discharge pipe and does not allow the unit to pump out the waste as efficiently as it should.
Oct 26, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
26 gallon model 919.167700 160 psi 1.6 hp Bottom of the compressor has a threaded air relief valve that cannot stop the compressed air from escaping. The compressor is new?! I tried using teflon tape...
if it's leaking from the center ,try loosening it let air blow out & tigthen .--- if it's leaking from the theads try tigthening it some more without breakage //////// this valve is the same as a metal radiator petcock with pipe threads that are tappered // return the compressor if still under warranty or try pipe dope -- check for crossed threads--buy new petcock from auto parts store .....a street elbow & 4'' of pipe & quarter turn vavle from the home depot ( or similer supply store ) works nicley as a replacement / this way you can reach the valve to drain the water with out laying on the ground.--------------1/4 pipe thread i think .
May 31, 2011 | Craftsman Air Tools & Compressors
My pressure washer starts and stops constantly. It seems to not hold pressure. Is that just a seal replacement?
It sounds like there is a leak in the output pipes or the non-return valve on the input to the pump is not sealing properly and allowing any pressure built up to leak back. If there are no leaks in the output pipes then it must be the non -return valve that is faulty. You could try removing the valve an cleaning it but usually once the valve seal is damaged, the only fix is replacement of the valve.
Nov 28, 2010 | Karcher Garden
The pump in my unit continues to try to pump.This happens around every 30 seconds
The problem is the non return valve probably at the elbow end of the unit. If it is a new unit then i would say the rubber has not been installed and if it is an old unit the rubber has probably become dislodged
Oct 07, 2010 | Saniflo & Saniplus& Macerator Pump
Hunts on and off when trigger is not depressed, checked for leaks and screen, also discharge, still does it.
There could be a small bit of grit stopping the non return valve in the inlet pipe from sealing fully which would allow a pressure drop causing it to hunt. The valve may also be just plain faulty.and require replacement.
Aug 24, 2010 | Karcher 1750 psi Electric Pressure Washer
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Model 01902 2350 psi . engine runs fine , sprays out nozzle but lower pressure and water sprays out plastic elbow on relief valve , that is supose to **** in soap if used , cant hold finger over spray from...
It sounds as if the non return valve in the elbow is the wrong way around .The o-ring normally goes in first then the ball then the spring. Try it and good luck.
Sep 08, 2009 | Garden
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
282 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
