Question about HP Pavilion a1200y (EK457AV) PC Desktop
A1200Y won't start
HP Pavillion a1200y. Had the system for about 3 years and then it started having issues with starting up. At first, it would not power on with a keyboard or mouse plugged in to the PS/2 ports.
I tried starting it without them plugged in and then plugging them in quickly before Windows started. Worked intermittently. Also tried using USB mouse and keyboard only with same results.
I've also replaced the power switch for the case and added a new PSU. I don't see any bulging capacitors or corrosion that would indicate a MB failure, but I suspect that could be the only problem. It also used to give the warning that the CMOS battery was dead and default settings were being used. Could that stop it from starting up? Should I attempt a replacement MB (E Bay has some). Trying to see if it's even worth the $50 to get it running again.
  • 54 Answers
Dead CMOS battery does not cause the problem you are describing. More likely your southbridge chipset is defective on your motherboard. Replace the motherboard.
Posted on May 30, 2010
Testimonial: "Excellent advice."
My cd/dvd player when playing music the sound is not constant and start to play like it slow and the dvd does the same is thair a repair for this or do i need to purchase a new cd/dvd burner/player my...
Kindly check first your software of your system.. sometimes occurred due to low performance of a system (software). do one thing, if the music your playing is from the disk... try to copy all that music from the disk and paste temporary to your hard drive.. once your done coping.. try to play the music from you hard drive.... if still same operation of your complain, means that the problem was on software....
Jul 11, 2011 | HP Computers & Internet
Drive F
You want to burn it direct to disc?
May 01, 2008 | HP Pavilion a1200y (EK457AV) PC Desktop
Having problems with finding the SM Bus Controller Driver for my hp pavilion a1200y.. motherboard Asterope-GL8E. any help would be great
click start control panel administrive tools,computer management,device manager scroll down universal serial bus controllers you could see a yellow question mark? right click to reinstall drivers or
if you can see the drive and its not working right click to update drivers also you might try
click start control panel administrive tools computer management disc management if you can see your drive right click select properties tools check now tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Apr 21, 2011 | Compaq (261671-001) Motherboard
My lying computer says a MS Word file I made a change to is read only. So I saved it as another file name but the computer will not let me see the new file name to change the name to the origional file...
It seems yr pc is infected with virus which hides the document files and create a .exe file. Kindly update the virus database and scan it. But still u cannot view the files even after cleaning the virus. They will remain as hidden. Go to the control panel>>> Folder Option>> Under the view tab click>>Show Hidden files and folders. I hope that will help.
Jul 29, 2010 | HP Computers & Internet
Need sata achi drivers so i can istall a sata hdd
You sure? Most of the time if your motherboard has sata connections then the bios should recognize the hard drive and once the computer comes up. It should come up with new hardware found and then install the drivers on it's own, however if it doesn't or won't go the the hard drive manufactures website and you should be able to find the drivers you need there. Probably under the drivers and help section of the website. Hope this helps
Jun 18, 2010 | HP Pavilion a1200y (EK457AV) PC Desktop
New memory not recognized by Compaq Pavilion a1200y
most probably the problem that you have is not on the RAM stick itself but on the memory slot. Both memories can be detected by slot 1 indicates that both are working.. both working memories cant be detected in slot 2 which indicates a bad memory slot
Mar 16, 2010 | Computers & Internet
I cannot go to windows xp! it is locked at the first screen with hp logo esc F1 and f12
Hello!
Please clean & reseat your RAM sticks & see if problem is solved. If no, remove your battery & put it after 1 or 2 min. Replace battery & proceed to power on.
If not solved go to your BIOS by holding F2 key & see if all your devices such as HDD, DVDRW are listed. May be your HDD has stopped functioning (AM SUSPECTING IT) or is not being detected. In that case it will not continue with booting after HP logo.
If HDD is damaged, you'll need to replace one.
Well, I hope that you get the fastest & cheapest solution. Good luck friend !
please send us your feedback if the advice helps, thanks!
Mar 05, 2010 | HP Pavilion a1200y (EK457AV) PC Desktop
Hp pavilion a1200y with windows xp home
Hmm,
It seems that you might either have a problem with your hard drive or you might have a huge Trojan that is not allowing you too sign on. If you cannot go to your desktop, you might have to get a new computer, if your finally able, try scanning it with a anti-virus.
Hope this helps,
TechGirl123
Feb 22, 2009 | HP Pavilion a1200y (EK457AV) PC Desktop
Computer shut down and windows password page came up. I cant remember the password.how can I reset it?
Turn the computer off. Turn it back on and start tapping F8 when you get the 'advanced boot options' choose safe mode and use the administrator account to change the password from there.
Jan 18, 2009 | HP Pavilion a1200y (EK457AV) PC Desktop
Drive F
You said that drive f is a CD/DVD burner. You can't save directly to a CD/DVD drive. If you would like to burn it to a disc, you need to save the file first and the use a burning program like Nero to burn to disc.
HP Pavilion a1200y (EK457AV) PC Desktop Logo
133 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
