Question about Dewalt 3800 PSI Pressure Washer
What soap do I use in my dewalt pressure washer
2 Suggested Answers
  • 942 Answers
SOURCE: My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Posted on Jul 05, 2009
Will not siphon
This model pressure washer will only siphon from the soap dispenser when you have the low-pressure nozzle attached and then will only sort of dribble out the suds. Good for sudsing, but no good for cleaning. You'll have to suds 1st then change to a highwe pressure spray nozzle to perform the actual cleaning. If it won't siphon with the low pressure nozzle either, then check for a blockage (old, dried soap) in the suction line tubing. Hope this helps!!
Oct 19, 2014 | Dewalt Pressure Washer. 3000 PSI 2.5 GPM...
Why won't It siphon soap?
These units use a venturi to inject soap, where the tube goes onto the brass barb, that should unscrew and there is a little ball bearing and spring in there that sometimes stick when thay have not been used for a little while, if you clean the ball bearing up with some steel wool and lube it up and reassemble, 9 times out of 10 this will rectify your problem
Hope this helps,
Brad
Jul 29, 2014 | Dewalt DPH3100 Gas Pressure Washer
What type of oil do i put in the DPD3100?
In the Pump Dewalt recommends
DeWalt DP70 Pressure Washer Pump OilIn the engine Dewalt Recommends
SAE 10W-30 is recommended for general use
Jun 26, 2011 | Dewalt DPD3100 Gas Pressure Washer
John deere 3800psi pressure washer will not siphon detergent. the water end does fine but cannot get any soap
The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
May 18, 2010 | Dewalt 3800 PSI Pressure Washer
My soap will not come out of the hose. What do i
several things to check, soap only works with low pressure tip installed, are you using correct tip? second issue is on bottom of soap tanks some have a small valve , is it open? is the tube blocked with dry soap or contamination, flusk it with water to be sure.
Apr 23, 2010 | Dewalt 3800 PSI Pressure Washer
In originally how is the warranty .
DEWALT Pressure washers warranty is as follows:
DEWALT pressure washers model year 2007 and prior (yellow frames) have a 2 year engine warranty, 1 year all other limited warranty.
DEWALT pressure washers model year 2008 (black frames) have a 2 year all components covered warranty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 19, 2010 | Dewalt 3700 Pressure Washer
Cannot get it to uptake the bleach for spraying Dewalt pressure washer 3100 psi
On most pressure washers you wont be able to draw soap/bleach into pump unless you are spraying on low pressure.There is a valve on the inside of inlet hose fitting that closes when high back pressure is sensed.Would it draw bleach into hose when wand tip is removed?
Nov 21, 2009 | Dewalt Garden
Dewalt 3700 pressure washer will not take in the cleaning solvents works fine but will not spray chemicals
Be sure that you have your chemical injector plumbed correctly. They will only work one way.
Oct 08, 2009 | Dewalt 3700 Pressure Washer
Dewalt 3800 PSI Pressure Washer Logo
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
