Question about Smart Modular SV3170A
Moniter power light blinks purple.
When plug my moniter into an outlet and into the compueter the power light blinks purple. If the moniter isn't plugged into the computer it still blinks purple. The screen is totally blank either way.
  • 11,361 Answers
Inspect the power supply and also try it on another PC too.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 31, 2010
Sir i have lg moniter w1643c i want to dish cable connection in this moniter how it is possible ?
try touching where the power light is blinking on the monitor. no button just touch with your thumb. then plug in to your dish
May 08, 2013 | Computers & Internet
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
Feb 22, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
No power to moniter
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor.
2. Connect the monitor into different power outlet.
3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Have a great day!
May 09, 2009 | HP L1702 17" LCD Monitor
No picture on screen but power light blinks
May be the problem with your Pc. If you can hear a beep sound when booting the Pc is Ok. Otherwise check memmory for loose connection.
May 03, 2009 | Computers & Internet
New acer 19 " moniter plug in will not turn on ?
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Thanks
Nov 09, 2008 | Acer AL1717 17" LCD Monitor
Monitor blinks no image
first you need to isolate the problem to either the computer or the moniter. I would sugust that you hook a know good moniter to the compter and go from there. If the other moniter works then you have a moniter issue aif not chek the video card in the computer. good luck
budman630
May 01, 2008 | E-Machines eMachines Monitor E15T4
Blinking Screen?
it is monitor problem,it should be EHT problem
Feb 29, 2008 | LG Flatron L1750S 17" LCD Monitor
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Smart Modular SV3170A Logo
97 people viewed this question
Top Smart Modular Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
