Question about Ovens
The light in the oven has blown it's fuse. Actually the top burners all have power however the oven and teh light and the clock do not have power. Where is the fuse located
  • jpspin May 30, 2010
    I am sorry however my husband could not find any fuse location so he called an Appliance Repairman and he should be out here on Tuesday. Thank you. Guess I get to eat out for 2 days.
  • Ovens Master
  • 4,924 Answers
Give it a look in the back where the power cable goes in ..the fuses are always located near by the power source ..(on the line ) ..it will be a lid ..or a screw-able cover of some kind..so if it has a square lid..take it off and see if they are placed inside...or ..it mat be more than one screw-able round covers ..but always in the back near the entry point of the cable ..
Posted on May 30, 2010
  • Catalin Turcu
    Catalin Turcu May 31, 2010
    this is a wise thing to do ..cause I give it a thought meanwhile and I do not think it is a fuse..but some other contact ..cause on these ovens ..the fuse will kill power for good..so it is probably another contact inside..or the transformer..
I have lost all power to the ovens and clock..but the gas igniter still works
No make or model given so answer is general in nature-
Burner igniters are not normally controlled by the main electronics board that supplies signals to the clock and oven controls.
This may be caused by a blown fuse on that board, a failure of the board itself or the power supply that provides operating voltage.
Feb 03, 2015 | Ovens
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
Oven and elements not working,
the oven and burner relay that supplies power to the bake/broil/top surface units is bad or the signal to latch this relay is missing from the control panel
Jun 03, 2012 | Moffat Ovens
My whirlpool oven display lights will not come on evn though teh unit has power and teh surface heaters work
What will cause that is a part on the clock that powers the display to illuminate has gone out yet the part of the clock (also called the electronic oven control) that send power to the heat elements is still working.It may work like that for years as long as you done mind the clock not displaying, OR to get it to display the clock/eoc would need to be replaced .
Gene
Aug 06, 2011 | Whirlpool Ovens
The center clock-oven module no longer lights up and the oven doesn't work, but the burners on top work. model rf341bxk. The oven light still works. Is there a fuse blown that I can replace?
Hello, welcome to fixya.
Unfortunately many modern ranges do not incorporate fuses into the control panels, other than the 15amp outlets used for plugging in external devices, they are typically the resettable type fuse.
Many manufactures have gone away from the typically glass fuse style circuit interrupters of previous ranges of say 15-20yrs ago and older.
If the clock display is not illuminated nor functioning, but the surface element functions appear fine, it is likely a fault within the clock ( also referred to as a timer or erc ) itself. Check for possible burnt or loose wires going into the timer such as L1 or L2 etc.
**Please unplug the range or turn off the 40amp breaker at your homes service panel before attempting any service to the range**
The part for the timer/clock is # 3196967 and retails for between $167 to $233 at "searspartsdirect.com" and "repairclinic.com" respectively as I type this on June 6/2010.
Hope this info was helpful to you...even if it isn't great news. Please take a moment and rate the info I provided and thanks for visiting "fixya".
macmarkus :)
Jun 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Hi, I cannot get the oven element or the back left burner to heat up.I found a blown 15 amp fuse blown in the oven and replaced it but still no power to the two elements. I took out the oven element to...
I take it when you mention burners you are refering to electrical hot plates?
If you have tested with 110V --even nthough it should be 240V then I can assume that the hob is working.
Possible cause is the regulator.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Ovens
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven control panel out
not likely a bloiwn fuse, you would have to gain acees to the control panel itself and check for incoming power supply, if your geting power to the clock the n youll need to replace clock. in the cabinet somewhere will be a wire diagram/trouble shooter. to aid you along
Apr 29, 2008 | Ovens
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
