Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 21 hp B&S model 407777/0229E1 on a Huskee rider. Battery and starter work great, and the flywheel turns fine but it doesn't produce any spark on either coil. The spacing between is correct?
3 Suggested Answers
  • 2841 Answers
SOURCE: what is the air gap b/t the flywheel & coil on
You can set the air gap with a business card or a feeler gauge. From .020 to .045 is correct. Just make sure you slowly turn the flywheel and it never touches the pickup after you set the gap.
Posted on Oct 01, 2010
eugbug
  • 479 Answers
SOURCE: need manual for briggs 407777 0229e1 trying to
An exploded parts diagram is available here:
http://www.briggsandstratton.com/engines/support/?NTT=4077770229E1
There are service manuals available here:
http://www.jackssmallengines.com/Products/BRIGGS-STRATTON/Manuals
Posted on Oct 04, 2011
Replaces battery and spark plugs in my huskee lawn tractor it cranks over but won't fire has full tank of gas and battery is charged what could be the problem?
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
Mar 28, 2017 | HP Garden
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Huskee Riding Mower wont start
Try rotating the engine manually to check for any binding. I would also check the amp draw on the starter.
May 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Starter doesn't engage the flywheel
Well since you replaced the starter, I think I would load test the battery cold and then again hot. It could be you have a dead cell in the battery and it is not producing enough voltage to work the starter solenoid.
Or it could be a bad connection between the battery and starter, or battery and ground.
Feb 13, 2013 | Ford Cars & Trucks
Won't turn over easily.
how new is the battery have it load tested to see.
Aug 23, 2012 | Garden
Hello, my LGTH2454 has been running fine. It sat for about an hour then I went to start it and the starter engaged on the flywheel but won't turn. I took the starter off and tested it. It seems to...
Sounds to me like the battery hasn't enough charge to turn the engine. Taking the starter off and testing it doesn't require much power as it doesn't have to turn the engine. Check the battery and also that the charging system is charging the battery back up. Alex.
May 20, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Huskee 18.5 lawn tractor, engin doesn;t wnat to turn over. sometimes starts and runs great other times acts like vapor lock or almost dead battery. has new battery, fully charged.
Take the starter cover off, look at the Plastic/metal gear. Is it in the up position on the flywheel, if so, the starter is not operating as it should. The gear should come back down out of the flywheel area. When the gears stay up like this, it causes the flywheel to be in a bind. The starter has to have the bendix to shift the gear up into the flywheel to turn over the engine. This is a common problem when a mower will start sometimes and hesitate like it don't have enough of battery power to turn it over, but in reality, it's binding and will burn the starter up if you try to start it too much.
Mar 28, 2010 | Garden
Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Jul 18, 2009 | Garden
Motor will not tun over
check to make sure the motor turns by hand, you may want to remove the sparg plug to make it a bit easier to turn, if it turns ok you may have stripped the gear on the starter or possibly the ringear
May 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
329 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
