Question about Vacuums
The part timer knob broke off so my husband took the toaster oven apart and now he does not know which parts to with which control.
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
Please check theuseful link bellow to get a detailed idea about your query…
http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
My electrolux ergorapido does not seem to have much suction, it is also very quiet. is this just the way it is?? i am the second owner, i have cleaned everything.
I took mine completely apart, removing every screw to get to the motor which was full of lint, hair and god knows what. I removed all the debris I could by hand, put it back together, and it works like new. I think debris gets in if the filter part is pushed too far down and the hole in the cup is open to the top part. My husband wanted to throw it out but I figured "what the heck". It's broken, it won't get more broken if I take it apart, it's only a year old.
May 09, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I am trying to repair a Sunbeam Model T-35 radiant control toaster. Everything is working but I can't seem to get the timer control (for setting light and dark) set correctly. Is there some...
I have/had a similar problem. Here's how I fixed it.
UNPLUG THE TOASTER
1. Clean the crumbs out throughly. I removed the bottom of the toaster (6 screws) to make sure all the debris was removed. Use a soft brush. Replace bottom and tighten screws. 2. Gently brush the sensor area in the 'one slice' slot with a soft brush. 3. Remove 'darker-lighter' knob. I gently pried mine off with a small screwdriver. 4. Plug toaster in. 5. Put a slice of your usual bread in the 'one slice' slot. 6. Watch it toast. 7. When 'done' to your liking slowly rotate the control counter clockwise using a small screwdriver until the toaster stops toasting. 8. Replace knob with the pointer at the mid point (up and down) to allow for minor adjustments.
Aug 18, 2011 | Sunbeam Vacuums
I cannot find the link to register my new convection toaster oven.
I would like to see if I could help you but, maybe I'm missing it, but I don't know what kind of toaster oven you have.
<a href="toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 15, 2011 | Vacuums
I have a Betty Crocker BC 1679C Toaster Oven and I need a replacement control knob (the dial that you turn to adjust the temperature). Can you please advide where I can find this part.
I couldn't come up with the part# or even who manufacturers Betty Crocker's appliances. I do notice on their website (bettycrockerstore.com) that they have an email contact for help with replacement parts. It is on the contact page. Under 'select a subject', choose 'product information'. "Help with replacement parts" is the second option. There is also an 800 number and a mailing address listed. Here is the site: http://www.bettycrockerstore.com/HelpContactUs.aspx
Hope this helps
Jan 30, 2011 | Vacuums
Took apart my electrolux 6500 sr. How do I get my fan shroud off to clean the blades? Thank you.
Oops. Don't. First blow it out with another canister vacuum or air hose. That's usually sufficient for removing dirt and dust. For dust/dirt in the motor, use a motor cleaning spray that can be picked up at most auto parts stores. One that evaporates quickly and doesn't leave a sticky residue. One's called Electric Motor Contact Cleaner by Gunk (http://www.gunk.com/CAT_NM1.asp). There are others.
Hobby shops may also have one available called Dynamite Magnum Force 2 Motor Spray.
It shouldn't be that dirty unless someone has been using generic "made to fit" Electrolux bags. Or if water or other liquid has been vacuumed, resulting in rust, etc.
Keep in mind that reassembling the vacuum is more difficult than taking it apart. If not done so correctly, various problems may result. While you have it apart, it would probably be a good idea to use pipe cleaners to clean out the tubes connectiong the "control valve assembly" to other parts of the vacuum. Also, unscrew the knob at the top of the "cva" to check for wear and breaks. Clean dust thoroughly from all interior parts.
Oct 05, 2010 | Electrolux Epic 6500 Vacuum
Hoover steamvac brushes don't spin. everything else works great. Took it apart and no visible problems
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
http://www.vacuumcleanershop.com/images/Hoover/F5903-900.GIF
parts list if you need some:
http://www.vacuumcleanershop.com/hvrmdlf5903.htm
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Jan 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My belt broke on my kirby upright, I took the roller off and put the new belt on, but I cant get the hook to hook on the belt.
On the front of the nozzle is a big knob that you turn to load the belt. Take the nozzle of of the vac, turn the knob to catch the belt, keep turning it until it stops. You will know if the it caught the belt, it will be hard to turn. Put the nozzle back on, lock, then turn the knob in the other direction releasing the belt unto the pulley.
May 01, 2008 | Vacuums
Hoover vacuum U6655-900
It is called the dirt sensor, you can try to re-attach the wires if there is enough there to do that. Otherwise you would have to replace the sensor, it may come with the duct(#21), the other end goes to the circuit board(#36) where the head light is. It tells you if there is a clog, when the light turns to red.
Feb 29, 2008 | Vacuums
No spray
pump part number is 2107181, the diverter valve # 2136988. You can Bissell and they can tell you who may have parts near you, or you maybe able to order thru Bissell.com. Before you took it apart, were you getting water to spray out of the hose. If you were the the heater is plugged and won't allow water to spray out the bottom.
Feb 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
