Question about Whirlpool DU1300XTV Builtin Dishwasher
Leaving chalk or soap on the dishes
When i clean my dishes it leaves soap or chalk like flim on the glass pot and pan
  • Whirlpool Master
  • 43,501 Answers
SOURCE:
Leaves a white soapy film on pots, pans and dishes
Are you overloading your dishwasher? Are you loading the dishes in such a way to cover the water shooting up from the blades? Have you run your dishwasher a few times with no dishes in it, adding straight white vinegar to clean it out? How old is your dishwasher?
Apr 02, 2013 | Whirlpool Dishwashers
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
No error message and is washing fine but it is rusting all my pots and pans and my cutlery also all my glasses are coming out all cloudy the dishwaser has also always asking for salt we have put in 3 bags...
Hi, I am only a housewife but salt is a corrosive. At home depo, menards, or lowes you can get a dishwasher cleaning kit. Use that to clean your dishwasher. Next because of new state and national laws soaps had to have a change in the chemical make up to have less sulfate or something like that. My glasses were cloudy all the time. I cleaned my dishwasher and now I
only put in dawn dish soap. I don't have to use anything else. My dishes come out clean and spotless. Now you may have to do a little more cleaning on your dishes before you put them in
because your not using regular dishwasher soap but I don't have those spots. Also I put about
a fourth teaspoon of the liquid soap in the 1st cycle soap dish and another fourth teaspoon in the 2nd cycle. You may have to experiment as to the amount you need becasue of how hard your
water is. If you put too much in soap suds will come out during the wash cycles. Hope is works
Marty Mouse the housewife.
Jun 05, 2011 | Dishwashers
My kitchenaid dishwsher is leaving a thick white film almost sale on the dishes. All the cyles seem to work.
Sorry to read about your problem, I hope this helps you out.
Do a wash with glass and pot, leave them upright so they fill of water...then look at the water. see if you can tell what the problem is soap,water, etc
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | KitchenAid Dishwashers
When i clean my dishes it leaves soap or chalk like flim on the pot and pan
Check if the rinse aid reservoir is not empty.
Add rinse aid or if ok increase the setting to let in more rinse aid.
Hope this fixes the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | Dishwashers
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
Leaves baked soap scum on utensils
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jun 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
My Frigidaire dishwasher is leaving soap, a lot of soap, on dishes under where the dispenser dispenses. It just started hapening. Also, it has always left a light film on the clear glasses.
I scrubbed the screens with a brush and added two cups of white vinegar to the bottom of the washer, then ran it. Cleaned up nicely. I most likely will add a cup of vinegar once a week.
Sep 13, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
My new ge dishwasher let my glasses and dishes uncleaned
I had a similar problem. Mine was leaving hard water deposits on my dishes. He had me take all of the metal out of the dishwasher (silverware, pots and pans, etc. Then run about 3/4 of a cup of Santeen de-limer through it. IT would clean the inside of the dishwasher nice, and would fix the problem. Unfortunately the hard water deposits would come back after a month or so, but would again be cleared by the Santeen...
Jun 11, 2009 | General Electric GLD69 24 in. Built-in...
Whirlpool DU1300XTV Builtin Dishwasher Logo
322 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
