Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
I purchased a used ipod shuffle. i just bought a charger for it and have itunes already on my computer for my daughters ipod nano... but the computer isnt recognizing my shuffle. how do i make this work
  • 11,896 Answers
Update the drivers for computer to recognize the player. You can go to the manufacture's website, download the drivers. Once downloaded, double-click the file that was just downloaded, then it will install the files into your computer. Then once installed, restart computer and then you should be good to go.
Posted on May 30, 2010
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
Aug 05, 2013 | Apple A1199 ipod nano
How do I add ipod shuffle to existing itunes account? I already have Ipod Nano on that account
Hello by adding to your account I'm guessing you want to be able to sync music that you've purchased via itunes. If you plug in your ipod and signed in under that account on the computer it should sync over if not you may need to go into "store" button at the top of itunes and authorize account for that comuter
Oct 03, 2011 | Apple iPod shuffle Second Gen. Silver (1...
Name change
This will loose the data already loaded to ipod. Turn on the iTunes and plug the ipod to that computer. wait until it recognizes the ipod when you see the name on the left side bar right click on it and rename it.
Feb 05, 2009 | Apple iPod nano
Cant get songs onto ipod shuffle.(daughter has ipod touch)
When you go into the ipod section on iTunes, click the music tab, make sure 'sync music' is checked and 'selected playlists:' is also, then check the playlist you want to use. Click 'sync' button
If that don't work go back to the summary tab and hit 'restore' and follow the instructions to reset the ipod, resync and all should be fine.
All the best
Sean
PiDigital
Dec 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Itunes download will only go to F drive
Have you tried downloading manually from:
http://www.apple.com/itunes/download/
If you can not select where to save it, maybe try using a different web browser, Firefox should do the trick.
Once downloaded, run the installer and it should update your current version.
Dec 28, 2008 | Apple iPod shuffle MP3 Player
Ipod Shuffle is not working! Please help!
I had the same problem with a new 2nd gen shuffle connecting it to my PowerMac G5 (OSX 10.4.11) with the latest iTunes (8.0.1). The problem is in the connector. The shuffle using the same connector for listening, syncing with iTunes, and charging. It appears to be insufficient for the G5 to interface with it because when I swapped it for a new Nano, the Nano worked just fine. I tried 2 new 2nd gen shuffles (and hours with in-store so-called genius's as well as tech supp in CA and noone could come up with a resolution). So I figured it had to be in the cable interface (the Nano using a multi-pin connection like the old ipod's used to) and that was exactly the problem. I spoke to someone who said they had a G4 and the shuffle worked fine with that, so it must just be a G5 issue.
Hope this helps....
Oct 20, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Sync Old iPod Shuffle & iPod Nano
Are you saying, that you want to know if you can use your old iTunes that you had for your shuffle, on your new ipod? If so, the answer is yes. Copy your itunes music on a pordable disk. When you plug your ipod into your computer, it will recogonize that it is a different ipod. A box will come up and ask you if you want to have a new library. Click yes and then you will have a new library. Put your disk(s) in and copy them over to your itunes.
I hope this helps, but I'm sorry if it doesn't. I didn't exactly get what you were saying. I haven't exactly tried this, but I think it will work. Please rate my solution.
Oct 18, 2008 | Apple iPod nano
Changed computers
I'm making an assumption that iTunes was working before on the other computer, and now that you have switched computers, the Nano is not being recognized by iTunes?
Try this, from Apple's website:
http://support.apple.com/kb/HT1339
Summary Learn how to restore iPod, iPod classic, iPod mini, and iPod nano to factory settings.
If you need to restore an iPod shuffle, click here.
Background It is important to understand the difference between "update" and "restore". Update simply installs the software that controls iPod and does not affect the songs and files stored on iPod's disk. Restore erases the iPod's disk and restores iPod to its original factory condition.
Warning: because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library. If you use the Nike + iPod Sport Kit, see this document for more information.
Products Affected iPod, iPod mini, iPod nano, iPod classic
How to restore iPod
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
Jun 25, 2008 | Apple iPod nano
Ipod shuffle syncing problem
i think u dont know how to use it
Mar 06, 2008 | Apple iPod nano
Ipod nano 4gb
If you install the itunes version 7.5 that you downloaded, you wont lose your music library. It is a separate file from the programs installation files. You don't need to uninstall the previous version, the new one will install on top of it.
Dec 23, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
200 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
