Question about Air King 20" Deluxe Box Fan with Thermostat: Box Fan Stand Accessory (no fan)
I have a Air King 20" box fan with thermostat. I need a new fan blade. Where can I get one. the model number is 9700.
    Problem Solver:
  • 8 Answers
Contact the manufacturer to see if replacement parts are available. Air King Limited Warranty Information
Posted on Jan 14, 2014
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: I manage an apartment building that was built in
Replacing the entire fixture might be a better choice than repairing the originals; they aren't that costly new.
If you want to pursue replacement motors, Johnstone Supply would be an excellent source if you have on in your area. It is a 'wholesale' supply company for trades-people but I have never been turned away and I've found their counter folks exceptionally helpful. For one thing, these motors are kind of generic so there are several brands that will have the same mounts, etc.
They also have a huge paper catalog you can request or pick up in their stores.
Try them:
Johnstone Supply
Posted on Sep 12, 2009
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Sep 28, 2009 | Dryers
I have an SMC ceiling fan, unknown what model number, which I bought from Canadian Tire a number of years ago. I had installed it once at a previous location, then moved and stored it for a while. I...
Good luck on that one, I needed one for a job & ended up buying a new fan, got tired of trying to find one. I'd watch for yeard sales. auctions, or even fans on sale at big chain stores like, walmart, home depot, or lowes. Not unusual to see complete fan for $20 -$30. Then use parts , or install entire fan.
Jul 10, 2009 | Heating & Cooling
Overheating when we turn on the AC
I would replace the fan clutch. When you are sitting still or have reduced airflow across the condensor and radiator the fan clutch should compensate for that by pulling in more air. They are designed to free wheel when not needed for fuel savings, and will only fully engage when hot. They are deceptive when diagnosing, they will feel "tight", but can still not function properly. If your engine is relatively clean, look at the shaft and the front of the fan clutch. If there is any evidence of oil with dust collected on the shaft or the spring on the front of the clutch, just replace it. I was in the radiator business for years and I can say with absolute certainty that this is the main culprit with your symptoms
Jul 07, 2009 | Air King 20" Deluxe Box Fan with...
Dometic 57915.531 - high fan does not work
If it is a wall mounted thermostat, then you need to check the control box mounted on the inside of the unit. Remove the inner shroud to access. Check for power on the blue wire entering the control box from the thermostat, this is the high fan circuit. There should also be power on the orange(or tan) wire from the tstat. This is the fan circuit. Both these need to be hot with 12VDC for the fan to run on high. If you have power there, try removing the cover from the inside and access the squirrel cage (fan blade) inside the unit, turn the tstat to High fan and try starting the fan motor by hand. If it starts, then you have a bad fan capacitor. If not, check power to the fan on the top unit and all wiring leading to the fan. If you have power to the fan and it still does not run, you need a new fan motor.
Hope this helps,
Jeff
Jun 08, 2009 | Dometic 57915531 Air Conditioner
Need the replacement lamp shad hampton bay
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Jan 03, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Need a new blade
Oct 01, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Air king problem
. You probably have too many time delays in your system and check the timer set points. sometime some thermostat has a time delay and the unit itself has a circuit board time delay.
Sep 02, 2008 | Weather King 10AJA2501AH Air Conditioner
Fan blade for a U2-20
I have a metal blade for the Patton U2-20 fan listed on ebay. The item number is 160273949463 and the listing ends on Wednesday August 27 at 10.00 p.m. I had this fan for 8 years and the motor has failed. Patton could not replace the motor since this is a discontinued item, and I figured that someone could use another blade for their fan. I hope this helps you!
Jun 27, 2008 | Patton Electric U2-20 Box Fan
Air King 20" Deluxe Box Fan with Thermostat: Box Fan Stand Accessory (no fan) Logo
78 people viewed this question
Top Air King Dryers Experts
Dan Webster
Dan Webster
Are you an Air King Dryer Expert? Answer questions, earn points and help others
